Author Topic: TP thread  (Read 11800 times)
Offline iri
Re: TP thread
« Reply #50 on: Tue, 07 July 2015, 05:27:38 »
I hate when you keep wiping and waiting for the TP to be 100% clean but it takes like 20 wipes and you're getting no where...
Then you just give up, say F it, and wear what you got left??
too far??
You are a murican, never give up! Just use wet tissues.
-Ray Bradbury
Offline abswyfe
  • I <3 Geekhack
Re: TP thread
« Reply #51 on: Tue, 07 July 2015, 06:50:05 »
3 for the front (abs says this is too much)
5 for the back (abs says this is too little)
And which one of you sicko mother****ers wipes from back to front?
I always run into someone who does when having this convo
Thank you all Destiny supporters and all you fun people in off topic! I think I will try to stick around for a while!
Offline henz
  • What?
Re: TP thread
« Reply #52 on: Wed, 08 July 2015, 04:54:39 »
Do you mean using the same to for both?!?
Who would want to drag poop in their vagina/penis?!?
That **** is crazy, its like asking for trouble
