Author Topic: [IC] ANSI & ISO TKL phantom plate.(modeled by Joey Quinn) JD40 style.  (Read 8507 times)
Offline wafflepc
I made this post on deskthority last week, and am just notifying everyone on geekhack about it! The groupbuy will be done on deskthority, so ill notify this thread when i am collecting payments. This is NON PROFIT, for the community!
http://deskthority.net/group-buys-f50/universal-tkl-phantom-plate-modeled-by-joey-quinn-jd40-style-t11039.html
« Last Edit: Thu, 09 July 2015, 10:13:18 by wafflepc »
Offline wafflepc
Re: [IC] ANSI & ISO TKL phantom plate.(modeled by Joey Quinn) JD40 style.
« Reply #1 on: Wed, 08 July 2015, 11:56:00 »
bumpity doo
Offline Data
« Reply #2 on: Wed, 08 July 2015, 20:13:58 »
OK...
You wanna link us the thread on DT, or is this more of a scavenger hunt sort of deal?
Offline FreeCopy
Keyboards
Poker II | Leopold fc500r | Bolt Modded M 1391401 x2 08NOV90 - 19NOV90 | FK-2001 White Alps Clones | Filco MJ2 104Bolt Modded SSK 1391472 27JUL87 | Winkeyless B.87 TKL | MiniVan GateReds 62g
Offline wafflepc
« Reply #4 on: Thu, 09 July 2015, 10:12:50 »
OK...
Oh so sorry! i thought i did haha!
Offline Data
« Reply #5 on: Thu, 09 July 2015, 19:14:39 »
OK...
Looks good, I'm in. Thanks for the link and for not taking my comment too seriously.  :cool:
Offline wafflepc
« Reply #6 on: Fri, 10 July 2015, 09:55:31 »
OK...
No problem, haha!
Offline wakko
« Reply #7 on: Fri, 10 July 2015, 10:04:28 »
In
NOOB
KUL ES-87
Offline punkpc
« Reply #8 on: Fri, 10 July 2015, 11:19:39 »
Is there anyway to get this with the additional cutouts for the phantom PCB?
Offline wafflepc
« Reply #9 on: Sat, 11 July 2015, 20:00:56 »
What do you mean? this is made for the phantom pcb.
Offline punkpc
« Reply #10 on: Sat, 11 July 2015, 20:43:50 »
So it has the extra buttons above the arrow cluster. Like this...
With the extended top row like the 7bit layout
Basically a lot like the design by hazeluff & TheProfosist for the function row and arrow cluster. That way you can use all of the Phantom PCB.
Regardless I'm in for it if it is the $70 or less price.
« Last Edit: Sat, 11 July 2015, 21:28:29 by punkpc »
Offline wafflepc
« Reply #11 on: Sat, 11 July 2015, 22:20:56 »
It will not, because it is meant to be used as a whole case, and used as a traditional TKL. It will be under $70 though!
Offline punkpc
« Reply #12 on: Sat, 11 July 2015, 22:48:43 »
That's kool, I understand. Still put me down for one though
Offline wafflepc
« Reply #13 on: Sun, 12 July 2015, 11:04:29 »
Ok!
Offline wafflepc
« Reply #14 on: Fri, 17 July 2015, 16:05:11 »
bump!
« Reply #15 on: Fri, 17 July 2015, 16:12:36 »
Just so I understand, what exactly is being offered here? A pair of plates for each order (switch plate and case bottom)?
Are you offering several layout choices for buyers, e.g. ANSI 125, ANSI 150, ISO 125, and ISO 150? Is there a MOQ for each layout?
Offline Data
« Reply #16 on: Fri, 17 July 2015, 16:25:03 »
Intriguing.
Offline wafflepc
« Reply #17 on: Fri, 17 July 2015, 18:52:40 »
Yes, it is a top plate with switch cutouts, and a metal plate with no cutouts for the bottom, to make a JD styled "case." It is ANSI 150 and ISO 150. I would prefer to get 5 of each, but that might not matter. This GB is for the community, and is non profit.
« Reply #18 on: Fri, 17 July 2015, 21:25:17 »
Ah, thank you for clearing that up for me. I think this is a good idea for anyone looking to build a Phantom, and who doesn't mind the 150 layout bottom row. Good work.
Offline punkpc
« Reply #19 on: Fri, 17 July 2015, 21:51:55 »
Shoot... U dropped the 125 ANSI layout?
« Reply #20 on: Fri, 17 July 2015, 22:20:46 »
I don't mean to sound salty, but if you're after an ANSI 125 keyboard, why wouldn't you simply buy a Filco, Ducky, or QFR?
Offline wafflepc
« Reply #21 on: Fri, 17 July 2015, 22:34:41 »
OOPS! Theyre both 125! sorry! had them mixed up!
Offline wafflepc
« Reply #22 on: Fri, 17 July 2015, 22:35:07 »
They are 125! i messed up! sorry!
Offline Data
« Reply #23 on: Mon, 20 July 2015, 19:04:25 »
I can't build my own Filco or QFR from scratch!
I'm definitely in for at least one, possibly 2 sets @ ANSI125.
Offline punkpc
« Reply #24 on: Tue, 21 July 2015, 14:12:05 »
Exactly :D
Offline wafflepc
« Reply #25 on: Wed, 29 July 2015, 09:39:45 »
Exactly :D
And gaterons, and nice controller  :D
« Reply #26 on: Wed, 29 July 2015, 09:42:28 »
Exactly :D
Drop-in replacement controller from bpiphany, and replace stock switches with Gaterons.
But, okay, I get why people want a Phantom. I just never saw the appeal of an 87-key Phantom build, and always built mine as 86-key versions.
Offline wafflepc
Offline braidn
« Reply #28 on: Mon, 10 August 2015, 16:48:39 »
totally IN but, couple questions though really quickly?
1. Is the mounting hardware included? Posts I guess?
1. My guess is that this would need to have Costar stabs?
1. And there is placement for Gon's feet (like his real feet, not the aluminum ones he sells  :p)... seriously though the aluminum ones?
Offline wafflepc
« Reply #29 on: Mon, 10 August 2015, 21:09:55 »
No, But they are easy to find.
Its cherry
And yes.
Offline trees
  • I like bagels.
« Reply #30 on: Tue, 01 September 2015, 15:14:39 »
just found this link. I would be in for one too.
B.Face HHKB - B.mini - Black/Purple Custom
Offline wafflepc
« Reply #31 on: Tue, 01 September 2015, 15:55:45 »
Please pm me on deskthority, im doing it through there. same username.
