Author Topic: Falbatech Compact Case questions  (Read 2514 times)
Offline ff6600
« on: Wed, 08 July 2015, 16:42:38 »
So after much deliberation I decided to acquire the parts for an Ergodox, I decided to go for the compact PVC case over at Falbatech. Has anyone had any experience building one with the case? The search hasn't told me anything.
Also I just noticed that the guys at Falbatech updated their site to say "Difficult to install. We recommend installation in FalbaTech."
Am I going to be shipping this back to Poland?
Thanks.
Offline davkol
  •  Post Editing Timeout
Re: Falbatech Compact Case questions
« Reply #1 on: Fri, 17 July 2015, 13:24:53 »
Some sanding might be required to fit the PCBs, but that's about it. I have no experience with the outer LED holes or a plate.
Offline ff6600
« Reply #2 on: Fri, 17 July 2015, 13:59:05 »
I discovered pretty quickly why they say it's a difficult build when it arrived.
Posted about it here: https://geekhack.org/index.php?topic=73557.0
Offline davkol
« Reply #3 on: Fri, 17 July 2015, 14:09:36 »
I see, you mean the case-plate variant. That's a different story.
