Author Topic: [WTS][EU] MAYA44 soundcard  (Read 4540 times)
Offline superbia
  • Trade Count: (0)
« on: Thu, 09 July 2015, 12:04:53 »
Hi guys. All prices are without shipping (5-15EUR to most EU countries) and paypal fees (around 3% of the total price). And I'm also considering offers and trades.
Everything will be shipped from Croatia (from a smoke free and pet free home).
FOR SALE:
AUDIOTRACK MAYA44 30EUR
Currently in my computer, willing to sell it because it lacks linux support.
The card is vintage, but is not obsolete. full specs here
1. Input Type : Analog 4 Input (TRS Stereo Phone Jack x 2), CD_In
2. Output Type : Analog 4 Output (TRS Stereo Phone Jack x 2),
SPDIF Out (Optical & Coaxial)
3. Input LEVEL : -10dBV Unbalanced, -10dBV Nominal, +3.0dBV Max
4. Output LEVEL : -10dBV Unbalanced, -10dBV Nominal, +3.0dBV Max
5. Input Impedance : 10K ohm
6. Output Impedance : 100 ohm
7. IN 1,2 Record Gain : Analog 0dB ~ 18dB, 1.5dB Step Size
8. IN 3,4 Record Gain : Analog 0dB ~ 18dB, 6dB Step Size
9. Input Monitor Gain : Analog -34.5dB ~ 12dB, 1.5dB Step Size
10. Output Attenuation : Analog -34.5dB ~ 0dB, 1.5dB Step Size
11. Master Output Attenuation : Analog -34.5dB ~ 0dB, 1.5dB Step Size
12. Sample Rate : 8KHz, 11.025KHz,
 22.05KHz, 32KHz, 44.1KHz,48KHz
13. A/D Spec
                1) Resolution : 18 bits
                2) Dynamic Range : 90 dB A-Weighted (Typical)
                3) THD+N : -87 dB Fs (Typical)
                4) Frequency Response : 20 ~ 20KHz
14. D/A Spec
                1) Resolution : 20 Bits
                3) THD+N : -86 dB Fs (Typical)
15. Digital Out Spec
                1) Type : Optical & Coaxial connector
                2) Format : IEC-958 Consumer, S/PDIF
                3) Sample Rate : 44.1KHz,48KHz
                4) Resolution : 16 Bits
16. Mic Preamp Spec
                1) Mic Input Gain   : +35dB Fix and +20dB on/off and 0dB ~ 18dB Variable
                2) Phantom Power    : +12V Phantom Power
17. Headphone Amp Spec
                1) Output Power : 100mW Maximum Output Power
                2) Signal to Noise Ratio : 110dB (Typical)
                3) (THD+N)/S : -70dB, 0.03%
As said it lacks the propper Alsa support , but I've had it successfully running on two different computers under windows 10.
If you are interested in the card I will provide you with the exact drivers I'm using.
WARNING: The card has 6.3mm jacks, some of which can be Phantom powered, and also there is a toggleable headphone amp.
So basically you can seriously damage your hifi tech if you don't know what you're doing.
SOLD
Kbt/Vortex Pure, read the condition 17EUR SOLD
- without case
- GATERON reds
- little shine on the caps
- pcb supports backlight
PROBLEMS WITH THE KEYBOARD:
#1 It has no case
#2 It's not 100% reliable. A few switches have "bad" leafs, and it could happen that you have a jammed key.
I could buy a new case, and replace the switches that occasionaly jam, but I lack time, effort  and love for ANSI.
So I'll be glad to have someone fix it, use it for parts or just practice soldering on it.
Before I ship it, I will clean the board, and I will open the switches that jam, and reposition the leaf (if its jammed) so that I make sure every key on the pcb works.
But if the keyboard vibrates too much during shipping, it's possible that once you plug it some keys aren't working.
WARNING:
Proceed only if you accept the risks mentioned above!!!
TAIHAO Dolch 10EUR SOLD
I think covers a fullsize keyboard + ISO mod ( + 3 spacebars, iso enter...)
The set is not 100% reliable, I had some problems with 3-4 caps getting stuck in my gaterons (not sure if was gaterons or caps problem).
Some of the caps have esthetical damage that probably occured during shipping when i recieved them (every damadged cap should be shown in  the pictures), and i did "ruin" the 1.75u right shift with a knife (while trying to make it "not get stuck in my switches").
--> I tried to remove some plastic underneeth it but i only made it worse....
I hope someone will find a use for this set.
KBT/Vortex Pure case. 20EUR SOLD
proof
QFR mx black: 60EUR TRADED
All keys tested and working. Has one tiny scratch on the bottom left edge (1mm diameter, not visible until close eye inspection).
The stock keyset is slightly worn out. That being said im including a new set taken from chinese ducky tkl (which is slightly higher quality), and I can also throw a pack of 100 ebay-orings (if desired).
Also in the box: usb cable, ps2 converter, some CM red keycaps (without the keypuller which i lost). All weights around 1.3kg.
Full album http://imgur.com/a/qyDsz
Creative soundblaster X-FI: asking 55 45eur shiped. SOLD
Unpacked, tested, and returned to the box.
« Last Edit: Tue, 16 February 2016, 08:24:01 by superbia »
Keebio Iris 2.8 (Alps) X Colemak Mod-DH
Offline superbia
  • Trade Count: (0)
Re: [WTS][EU] QFR mx black, Creative soundblaster X-Fi
« Reply #1 on: Fri, 10 July 2015, 14:11:29 »
added the soundblaster
Offline lolpes
  • Trade Count: (0)
« Reply #2 on: Fri, 10 July 2015, 15:12:30 »
Pm'd ;) got someone who will love this as a gift
Offline superbia
  • Trade Count: (0)
« Reply #3 on: Thu, 16 July 2015, 01:00:37 »
bump
Offline superbia
  • Trade Count: (0)
« Reply #4 on: Sat, 18 July 2015, 01:54:06 »
weekend bump
Offline superbia
  • Trade Count: (0)
« Reply #5 on: Mon, 20 July 2015, 16:29:26 »
new week bump
Offline flabbergast
  • Trade Count: (0)
Re: [WTS/T][EU] Creative soundblaster X-Fi
« Reply #6 on: Mon, 03 August 2015, 14:26:49 »
Got the QFR, all good, thanks!
Offline Rainman
  • Trade Count: (0)
Re: [WTS/T][EU] Vortex Pure PCB/case/caps, gateron reds, taihao dolch
« Reply #7 on: Sat, 19 September 2015, 10:27:31 »
Already PM'ed for the case
Rocking Poker 2 with vintage MX Blacks
Offline Zorox
  • Trade Count: (0)
  • Tactile FTW <3
« Reply #8 on: Sun, 20 September 2015, 06:08:58 »
PM'ed for the Taihao Dolch set.
Offline superbia
  • Trade Count: (0)
Re: [WTS/T][EU] Pure PCB/caps, gateron reds
« Reply #9 on: Wed, 30 September 2015, 01:50:52 »
BUMP !
Offline Rainman
  • Trade Count: (0)
« Reply #10 on: Wed, 30 September 2015, 07:29:10 »
Got the case, everything packed and shipped OK. Would buy again.
Offline superbia
  • Trade Count: (0)
Re: [WTS][EU] Kbt/Vortex Pure 20Eur
« Reply #11 on: Wed, 25 November 2015, 13:29:05 »
update!
Offline superbia
  • Trade Count: (0)
Re: [WTS][EU] Kbt/Vortex Pure (for parts)
« Reply #12 on: Fri, 18 December 2015, 14:25:51 »
Advent Bump
Offline superbia
  • Trade Count: (0)
Re: [WTS][EU] MAYA44 soundcard
« Reply #13 on: Mon, 21 December 2015, 11:52:51 »
All the keyboard parts have been sold. MAYA44 added.
Offline lolpes
  • Trade Count: (0)
« Reply #14 on: Wed, 30 December 2015, 11:08:49 »
The board is here and everything works :D just changed the caps with some from my secret santa gift ^^
Offline superbia
  • Trade Count: (0)
« Reply #15 on: Wed, 30 December 2015, 11:13:58 »
Thanks mate, glad you like it.  :)
Offline superbia
  • Trade Count: (0)
« Reply #16 on: Tue, 16 February 2016, 08:11:54 »
february bump  :thumb:
