Author Topic: A keycap idea I had  (Read 3988 times)
Offline mdszy
  • ayy lmao
    • mdszy
A keycap idea I had
« on: Thu, 09 July 2015, 16:48:03 »
I had a bit of an idea for a design for keycaps to replace number-row keys. I thought it'd be interesting to have keys where instead of the number being the primary focus of the legend, the symbol assigned to the key was instead and the number could be side-printed or simply omitted.
I made the design in keyboard-layout-editor.com here.
What do you guys think?
Das Keyboard Ultimate | Razer Blackwidow Tournament Edition | Pok3r
Offline njbair
    • nickbair.net
Re: A keycap idea I had
« Reply #1 on: Thu, 09 July 2015, 22:31:24 »
Interesting idea, not sure if I've seen that done before.
I doubt 60% users would like it, though, because they are probably mapping the F-keys to that top row on a different layer, and without number legends it would be hard to tell which one you're about to press.
My boards:
Offline TastaturenAuslese
  • Formerly temence
  • life marrow suckerer
« Reply #2 on: Thu, 09 July 2015, 22:46:45 »
I think this would look great! Would definitely be down to buy this if it were to become a real thing, especially from my blank Topre HHKB :)
Can you imagine a blank keyboard with !@#$%^&*() all over the top. That would look pretty awesomely minimalistic and artistic at the same time.
Home: Kishsaver - IBM 6019284/F62 | Work: HHKB Professional 2 Silenced | Temporary Retirement:
IBM '89 1391401 Merrill Lynch Financial Edition
They are a functional and practical indulgence.
Offline mdszy
  • ayy lmao
    • mdszy
« Reply #3 on: Fri, 10 July 2015, 00:12:07 »
So if I do want to make this real...where do I start? I honestly have no idea :s
Offline Oobly
« Reply #4 on: Fri, 10 July 2015, 01:43:46 »
This could work, especially if you also add homing bumps on 4 and 7.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
  • Formerly temence
« Reply #5 on: Fri, 10 July 2015, 02:11:04 »
I'm guessing you'd have to do an interest check to see how many people would consider paying for this. And then of course you'd have to find a supplier that can print these caps for you.
Offline rm-rf
« Reply #6 on: Fri, 10 July 2015, 02:13:45 »
i would like it if it was the other way around.
Offline mdszy
  • ayy lmao
    • mdszy
« Reply #7 on: Fri, 10 July 2015, 10:09:02 »
Why's that, exactly?
So you mean with numbers big and centered and symbols side printed?
  • Formerly temence
« Reply #8 on: Sun, 12 July 2015, 02:48:50 »
The homing bumps are to guide people's hands, just like the ones on F and J. That way you have your left 4 four fingers covering 1234 and your right covering 7890. You move your left index if you want 5 (from 4), and you move your right index finger to 6 (from 7).
Another option is to side print ONLY the 5 and the 0, and leave the other sides blank. This makes it easier to locate the numbers by proximity, and also to know where your number row ends.
Offline rm-rf
« Reply #9 on: Sun, 12 July 2015, 02:57:49 »
yes.
Offline Giorgio
« Reply #10 on: Sun, 12 July 2015, 17:43:03 »
Granite had this option.
French layout is made like this.
About the homing, I've tried it with dsa profiles and it works quite well.
« Last Edit: Mon, 13 July 2015, 09:20:58 by Giorgio »
Offline v0idtek
  • I make 3D printed stuff for keyboards.
    • v0idtek
« Reply #11 on: Mon, 20 July 2015, 12:32:30 »
The Vortex PBT/POM keycaps I use feel like that, just because the symbols are the ones that shine through with backlighting and the numbers themselves stay opaque underneath.
These are up on massdrop all the time.
3D printed stuff for keyboards:
www.v0idtek.com
