Author Topic: Where can I buy a Caps Lock keycap?  (Read 3846 times)
Offline db268
« on: Tue, 14 July 2015, 16:57:59 »
I'm missing a CapsLock keycap on my set. I've searched basically everywhere but found nothing. It's just 1 keycap, a CapsLock. Why is it so hard to find a shop or a particular vendor willing to find a CapsLock key? Any help would be really appreciated  :)
Offline SidusNare
  • Do, or do not; there is no try.
Re: Where can I buy a Caps Lock keycap?
« Reply #1 on: Tue, 14 July 2015, 17:05:35 »
What kind of stem? What width?
To doubt everything or to believe everything are two equally convenient solutions; both dispense with the necessity of reflection. -- H. Poincare
Offline db268
« Reply #2 on: Tue, 14 July 2015, 17:15:50 »
I have a Leopold 660M, so can be any stem correct? Width would be 1.75 I believe.
Offline VinnyCordeiro
« Reply #3 on: Tue, 14 July 2015, 17:31:57 »
You can buy single keycaps at http://www.wasdkeyboards.com/
Offline db268
« Reply #4 on: Tue, 14 July 2015, 17:48:14 »
