Author Topic: What are the dimensions of TKL Plates?  (Read 4080 times)
Offline Dihedral
  • Mostly Harmless
« on: Wed, 15 July 2015, 13:38:39 »
Quick thread to ask for the dimensions of TKL Plates. I haven't been able to find any definitive numbers through google.
Tags for future searchers - Phantom TKL Dimensions Size Filco QuickFire Rapid
Offline davkol
  •  Post Editing Timeout
Re: What are the dimensions of TKL Plates?
« Reply #1 on: Wed, 15 July 2015, 13:51:42 »
My QFR plate is 348×128 mm without the part bent downwards.
Offline user 18
« Reply #2 on: Wed, 15 July 2015, 14:07:22 »
It varies a little bit, because there isn't a hard and fast standard for spacing between the alpha cluster and F-row, or between the alpha cluster and nav cluster. If there's a particular case you're trying to fit, you need to look for already-existing plates that fit that case, and use those dimensions. If you're building your own case, you have all the flexibility in the world.
Avatar by ashdenej
Offline Dihedral
  • Mostly Harmless
« Reply #3 on: Wed, 15 July 2015, 14:12:41 »
The phantom and othersare supposedly universal plates - what dimensions are they?
Offline user 18
« Reply #4 on: Wed, 15 July 2015, 14:17:15 »
Universal just means that they don't restrict you to a particular key layout -- at least that's how I've seen it used.
CAD files for phantom plates are available here: http://deskthority.net/wiki/Phantom
You should be able to get the dimensions out of that, if you have something that can open .dxf
Avatar by ashdenej
Offline Dihedral
  • Mostly Harmless
« Reply #5 on: Thu, 16 July 2015, 01:55:59 »
I'll check them out,  thanks.
