Author Topic: TMK Firmware Error  (Read 2128 times)
Offline Davsmith4
TMK Firmware Error
« on: Wed, 15 July 2015, 13:42:02 »
So im on the final parts of building my keyboard. I just finished editing TMK's code using Matto3's guide and when i got to run the make file I get this error then everything else fails after that...
Please help I dont want my keyboard to be come $100 collection of wires and switches that doesnt work :P
keymap_common.h:47:1: error: parameter name missing
keymap_common.h:48:1: error: expected identifier or '(' before '{' token
And here is the code (all of it) from keymap_common.h
Code: [Select]
#ifndef KEYMAP_COMMON_H
#define KEYMAP_COMMON_H
#include <stdint.h>
#include <stdbool.h>
#include <avr/pgmspace.h>
#include "keycode.h"
#include "action.h"
#include "action_macro.h"
#include "report.h"
#include "host.h"
#include "print.h"
#include "debug.h"
#include "keymap.h"
extern const uint8_t keymaps[][MATRIX_ROWS][MATRIX_COLS];
extern const uint16_t fn_actions[];
/* GH60 keymap definition macro
 * K2C, K31 and  K3C are extra keys for ISO
#define KEYMAP( \
    K00,      K02, K03, K04, K05, K06, K07, K08, K09, K0A, K0B, K0C, K0D, K0E, K0F, K0G, \
    K10, K11, K12, K13, K14, K15, K16, K17, K18, K19, K1A, K1B, K1C, K1D, K1E, K1F, K1G, K1H, K1I, K1J, K1K, \
    K20, K21, K22, K23, K24, K25, K26, K27, K28, K29, K2A, K2B, K2C, K2D, K2E, K2F, K2G, K2H, K2I, K2J, \
    K30, K31, K32, K33, K34, K35, K36, K37, K38, K39, K3A, K3B,      K3D,                K3H, K3I, K3J, K3K, \
    K40, K41, K42, K43, K44, K45, K46, K47, K48, K49, K4A,           K4D,      K4F,      K4H, K4I, K4J, \
K50, K51, K52,           K55,                K59, K5A, K5B,      K5D, K5E, K5F, K5G, K5H,      K5J, K5K, \
    { KC_##K00,  KC_NO  , KC_##K02, KC_##K03, KC_##K04, KC_##K05, KC_##K06, KC_##K07, KC_##K08, KC_##K09, KC_##K0A, KC_##K0B, KC_##K0C, KC_##K0D, KC_##K0E, KC_##K0F, KC_##K0G}, \
    { KC_##K10, KC_##K11, KC_##K12, KC_##K13, KC_##K14, KC_##K15, KC_##K16, KC_##K17, KC_##K18, KC_##K19, KC_##K1A, KC_##K1B, KC_##K1C, KC_##K1D, KC_##K1E, KC_##K1F, KC_##K1G, KC_##K1H, KC_##K1I, KC_##K1J, KC_##K1K} , \
    { KC_##K20, KC_##K21, KC_##K22, KC_##K23, KC_##K24, KC_##K25, KC_##K26, KC_##K27, KC_##K28, KC_##K29, KC_##K2A, KC_##K2B, KC_##K2C, KC_##K2D, KC_##K2E, KC_##K2F, KC_##K2G, KC_##K2H, KC_##K2I, KC_##K2J, KC_NO} , \
    { KC_##K30, KC_##K31, KC_##K32, KC_##K33, KC_##K34, KC_##K35, KC_##K36, KC_##K37, KC_##K38, KC_##K39, KC_##K3A, KC_##K3B,  KC_NO  , KC_##K3D,  KC_NO  ,   KC_NO ,   KC_NO , KC_##K3H, KC_##K3I, KC_##K3J, KC_##K3K} , \
    { KC_##K40, KC_##K41, KC_##K42, KC_##K43, KC_##K44, KC_##K45, KC_##K46, KC_##K47, KC_##K48, KC_##K49, KC_##K4A,  KC_NO  ,  KC_NO  , KC_##K4D,  KC_NO  , KC_##K4F,   KC_NO , KC_##K4H, KC_##K4I, KC_##K4J, KC_NO} , \
{ KC_##K50, KC_##K51, KC_##K52,  KC_NO  ,  KC_NO  , KC_##K55,  KC_NO  ,  KC_NO  ,  KC_NO  , KC_##K59, KC_##K5A, KC_##K5B,  KC_NO  , KC_##K5D, KC_##K5E, KC_##K5F, KC_##K5G, KC_##K4H,  KC_NO  , KC_##K5J, KC_##K5K} \
/* ANSI valiant. No extra keys for ISO */
#define KEYMAP_ANSI( \
    K00, K01, K02, K03, K04, K05, K06, K07, K08, K09, K0A, K0B, K0C, K0D, \
    K10, K11, K12, K13, K14, K15, K16, K17, K18, K19, K1A, K1B, K1C, K1D, \
    K20, K21, K22, K23, K24, K25, K26, K27, K28, K29, K2A, K2B,      K2D, \
    K30, K32, K33, K34, K35, K36, K37, K38, K39, K3A, K3B,           K3D, \
    K40, K41, K42,           K45,                     K4A, K4B, K4C, K4D  \
) KEYMAP( \
    K20, K21, K22, K23, K24, K25, K26, K27, K28, K29, K2A, K2B, NO,  K2D, \
    K30, NO,  K32, K33, K34, K35, K36, K37, K38, K39, K3A, K3B, NO,  K3D, \
    K40, K41, K42,           K45,                NO,  K4A, K4B, K4C, K4D  \
#define KEYMAP_HHKB( \
    K00, K01, K02, K03, K04, K05, K06, K07, K08, K09, K0A, K0B, K0C, K0D, K49,\
    K30, K32, K33, K34, K35, K36, K37, K38, K39, K3A, K3B,      K3D, K3C, \
) KEYMAP( \
    K30, NO,  K32, K33, K34, K35, K36, K37, K38, K39, K3A, K3B, K3C, K3D, \
    K40, K41, K42,           K45,                K49, K4A, K4B, K4C, K4D  \
#endif
Offline VinnyCordeiro
Re: TMK Firmware Error
« Reply #1 on: Wed, 15 July 2015, 14:28:13 »
The keymaps are not matching. Note the first part of the code:
Code: [Select]
#define KEYMAP( \
It defines a keyboard with 21 columns. Then the second part of the code:
Code: [Select]
) KEYMAP( \
) KEYMAP( \
All of these alternative keymaps are defined for a 14 columns keyboard (an standard 60%).
You may either correct the second part or delete it entirely and your code should compile. Hopefully.
Offline Davsmith4
« Reply #2 on: Wed, 15 July 2015, 14:35:53 »
OK thanks! Silly me forgot to delete that :P
So that error is now gone but now im getting this one.
keymap_poker.c:4:5: error: 'KEYMAP' undeclared here (not in a function)
     KEYMAP{ESC,   F1,   F2,   F3,   F4,   F5,   F6,   F7,   F8,   F9,  F10,  F11,  F12,        PSCR, SLCK,  BRK, \
keymap_poker.c:4:11: error: expected '}' before '{' token
Here is the code for that file...
Code: [Select]
const uint8_t PROGMEM keymaps[][MATRIX_ROWS][MATRIX_COLS] = {
           GRV,    1,    2,    3,    4,    5,    6,    7,    8,    9,    0, MINS,  EQL, BSPC,  INS, HOME, PGUP,      NLOCK, SLSH, * , MINS, \
           TAB,    Q,    W,    E,    R,    T,    Y,    U,    I,    O,    P, LBRC, RBRC, NUHS,  DEL,  END, PGDN,      7, 8 ,9,     \
           CAPS,    A,    S,    D,    F,    G,    H,    J,    K,    L, SCLN, QUOT,        ENT,                       4, 5, 6, PLUS,     \
           LSFT, NUBS,    Z,    X,    C,    V,    B,    N,    M, COMM,  DOT, SLSH,       RSFT,         UP,           1,2,3,     \
           LCTL, LGUI, LALT,              SPC,                         RALT, RGUI,  APP, RCTL, LEFT, DOWN, RGHT,    0,DOT,ENT),
const uint16_t PROGMEM fn_actions[] = {
TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, \
TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, \
TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS, TRNS),
Im sure these errors would be obvious to anyone with experience but im very new to programming. Thanks for the help
Offline Davsmith4
« Reply #3 on: Wed, 15 July 2015, 15:09:43 »
Code: [Select]
#define KEYMAP( \
Code: [Select]
) KEYMAP( \
) KEYMAP( \
Oh so I fixed the other error. Stupid mistake I typed { isntead of (
Now the next error is this:
keymap_common.h:49:178: error: 'KC_NLOCK' undeclared here (not in a function)
