Author Topic: Anyone know anything about this Model M?  (Read 1808 times)
Offline Regal
« on: Fri, 17 July 2015, 10:31:40 »
Just found a bunch of old keyboards at a university overstock place (again!).
1) A Model M 1390120
2) A working but dirty Model F (which I'm typing on now)
3) And 4 of a model that I've never heard of before that has some crazy keycaps. It's Model M 1399680 and looks like this (see attached pics that I hurriedly took, as I really had to go to the bathroom).
I already bought the first two (were selling each for $40 and gave me a pretty decent discount), but I was wondering if it would be worth it for the 4 Model M 1399680s? There're also $40 each, but I can probably talk them down to $30.
Regal
P.S. Those keycaps!
« Last Edit: Fri, 17 July 2015, 10:39:15 by Regal »
Re: Anyone know anything about this Model M?
« Reply #1 on: Fri, 17 July 2015, 10:45:19 »
The old ones are nice because they have the heavy plates, but if they aren't 1390120s then they are probably terminal boards that will need a converter.
$40 is a little high for a terminal.
- D Trump 2026-10-24
Offline Regal
« Reply #2 on: Fri, 17 July 2015, 10:56:19 »
Thanks fohat for your fast reply. You're always on your game! I noticed they were terminals, but was hoping they were especially collectible or something. I have no idea what the university was using them for up till now...
I think I'll return the first one too, as I tested it out and there seems to be something wonky about the connection. But hey, $30 for a model f is a pretty great haul by itself!
-Regal
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #3 on: Fri, 17 July 2015, 11:00:54 »
3) And 4 of a model that I've never heard of before that has some crazy keycaps. It's Model M 1390680 and looks like this (see attached pics that I hurriedly took, as I really had to go to the bathroom).
I already bought the first two (were selling each for $40 and gave me a pretty decent discount), but I was wondering if it would be worth it for the 4 Model M 1390680s? There're also $40 each, but I can probably talk them down to $30.
Regal
P.S. Those keycaps!
Terminal conversions are pretty cool, considering I am using my 1392595 now.  You could buy a controller for them and an LED panel and overlay from Unicomp.  And you will need an SDL cable as well.  So figure that $30 terminal board will cost you about $20 for the controller, $10 for the LED panel, $1.50 for the overlay, and $15 for the SDL cable.   A total of about $46.50 plus shipping....
But worth it if you really really want to use it on your PC.  I have done several.
http://imgur.com/a/bBFuv
http://imgur.com/a/iNjFR
http://imgur.com/a/O7ayY  <-- Currently typing on this one.
A couple Phosphorglow bolt-modded ones as well....
http://imgur.com/a/akDm6
http://imgur.com/a/gQS7O
http://imgur.com/a/tIonH
It's worth it to me.
Offline Regal
« Reply #4 on: Fri, 17 July 2015, 11:05:23 »
Hmm, I'm tempted to do that Snowdog. Maybe I'll exchange the first one I mentioned for one of those and set it up. They are pretty darn cool, after all :)
Regal
« Reply #5 on: Fri, 17 July 2015, 11:14:47 »
My experience is that the heavy plates were used until at least early-mid-1987.
Offline Snowdog993
« Reply #6 on: Fri, 17 July 2015, 11:16:56 »
Regal
The 1390120 is a very nice keyboard in it's own right.  It can be used with your PC right away.  Did it come with the SDL cable?  If not, you may need one for it, and you're good to go.
Oh! I didn't see that reply you had to Fohat.  Nevermind.
« Last Edit: Fri, 17 July 2015, 11:21:33 by Snowdog993 »
