Author Topic: [GB][DONE] ROUND 2 LeandreN plate(designed by JDcarpe) + SPRiT PCB  (Read 252712 times)
Offline Jixr
Re: [GB][Shipping & Waiting] LeandreN plate(designed by JDcarpe) + SPRiT PCB
« Reply #700 on: Fri, 02 October 2015, 11:28:56 »
Hopefully my CF plate will come in the mail today.
I'm actually going to use it on a much larger board I don't have a plate for , but if it does not work, I may end up re-selling it, so if any of you guys missed out on one of the 5 Carbon Fiber plates, you may have another chance.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #701 on: Fri, 02 October 2015, 11:30:18 »
I know a guy who would love one!
Offline E3E
« Reply #702 on: Fri, 02 October 2015, 11:43:41 »
That would be me! If it doesn't work out, I'll buy it ASAP, Jixr. I'll send you a PM! LeandreN knows how much I've been going crazy about having one, lol.
Offline Jixr
« Reply #703 on: Fri, 02 October 2015, 13:52:12 »
I would like to put it on my redscarf, but if the probably likely reason it won't fit how i imagine it to, then i'll have a post in the classy. ( or you can entice me with trade offers via PM )
Offline fgsz291
« Reply #704 on: Fri, 02 October 2015, 14:19:10 »
Hi, I just finished my build today and it surely was fun but I have quite a big problem. The keyboard stopped working after sometime and pluging it out and in again, the PC did not identify it. I tried to upgrade the firmware but it said "problems downloading.." and now it stopped working at all. Did I kill something on the keyboard or is it possible to reset the firmware somehow? thanks
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #705 on: Fri, 02 October 2015, 14:53:29 »
Not great.
I am not sure what's happening here. I would refer to the SPRiT 60% parts thread for assistance. People here are also really helpful. If you don't find anything that helps you, contact me and I can see if I can send a replacement. I also sent a mail to SPRIT, but i doubt he will answer anytime soon.
Offline TalkingTree
    • My projects
« Reply #706 on: Sat, 03 October 2015, 03:58:21 »
Is it possible to reset the firmware somehow?
SPRiT's 60% is a FaceW so you can use this tutorial.
Offline fgsz291
« Reply #707 on: Sat, 03 October 2015, 05:24:54 »
Thank you, I already posted there too, and tried everything written there. The Problem is my board does not get into the bootloader I guess.
Offline TalkingTree
    • My projects
« Reply #708 on: Sat, 03 October 2015, 06:00:36 »
Meaning it doesn't get into bootloader state by plugging the usb cable with the Q key pressed down?
If you have remapped it to somewhere else, for example to get a Dvorak layout, I guess you still need to hold the default Q key down as it's the first key in the matrix.
Offline fgsz291
« Reply #709 on: Sat, 03 October 2015, 06:07:34 »
Yes it will not be recognized by Windows and it doesn't start up in the bootloader while pressing Q, U or P.I haven't remapped anything, I tried flashing it because it randomly disconnected and started to key chatter (After all I guess the connector has a loose connection). And I guess it disconnected while flashing and stopped working at all now...
Are there any leftovers or anyway I can get a new board for around the same price?
Offline TalkingTree
    • My projects
« Reply #710 on: Sat, 03 October 2015, 08:45:17 »
Try with Zadig.
Offline fgsz291
« Reply #711 on: Sat, 03 October 2015, 09:07:47 »
Try with Zadig.
The computer says "no driver found" and Zadig says driver was installed successfully
Offline TalkingTree
    • My projects
« Reply #712 on: Sat, 03 October 2015, 10:13:37 »
Try with Zadig.
Might be dead then, but await for a second opinion before dumping.
Offline fgsz291
« Reply #713 on: Sat, 03 October 2015, 10:19:47 »
Thank you, I am afraid you might be right :(
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #714 on: Sat, 03 October 2015, 10:21:37 »
Replacement then...
Trying to ask SPRiT first. Also, I'm need to wait for a transaction before shipping stuff.
Offline fgsz291
« Reply #715 on: Sat, 03 October 2015, 10:28:04 »
Thanks for the help, no need to hurry, I'm not in a rush. Just PM me if you need something and how much I owe you.
Offline bigDave
  • The biggest
« Reply #716 on: Sat, 03 October 2015, 14:36:50 »
Mine parts have arrived, but I am at uni so no build yet.
A big thank you for organizing the group buy!  :thumb: :thumb:
Offline MarkRobbo
« Reply #717 on: Sat, 03 October 2015, 15:26:26 »
Had chance to unpack my order, got here in perfect condition and looks good, but no build yet due to uni similarly to others  :thumb:
Have a hammer case to house it so should be nice!
Offline ika
« Reply #718 on: Sat, 03 October 2015, 22:12:31 »
Got my plate today! The anodizing is very nice. Did not expect how tightly it holds onto switches, but it functions perfectly as a lube station as well until I figure out how I want to set up the whole board.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #719 on: Sun, 04 October 2015, 07:17:42 »
Thanks for posting!
Offline DanielT
« Reply #720 on: Sun, 04 October 2015, 13:06:03 »
If you have any extra PCB's I'm interested in one :)
Offline swornxin
    • Nailed Down Custom Pins
« Reply #721 on: Mon, 05 October 2015, 00:26:42 »
Agreed.
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline tofgerl
« Reply #722 on: Mon, 05 October 2015, 00:57:00 »
We all are, let's just wait till he announces if he has any left.
Offline joey
« Reply #723 on: Mon, 05 October 2015, 03:30:03 »
Got my plate today! Looks like it might need to spend a bit of time under something heavy.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #724 on: Mon, 05 October 2015, 03:30:48 »
Pics?
Offline joey
« Reply #725 on: Mon, 05 October 2015, 03:32:38 »
Pics?
Later, I'm at work so it's still packaged up. The package looks only slllliiiiiiightly bent, so I'm not too worried.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #726 on: Mon, 05 October 2015, 03:33:57 »
Pics?
Okey :)
Offline Jixr
« Reply #727 on: Mon, 05 October 2015, 09:35:39 »
about half the plates that i've ordered from people on here and keyboard websites show up bent, I hate when people mail them in unprotected bubble mailers. though i'm sure mine from leandren will be good
Though my computer pooped the bed this weekend, so i'm 99% certain i'll be re-selling my carbon fiber plate once it comes in.
EDITED FOR CLARITY
« Last Edit: Mon, 05 October 2015, 11:09:23 by Jixr »
Offline E3E
« Reply #728 on: Mon, 05 October 2015, 09:58:50 »
about half the plates that i've ordered show up bent, pro tip to everyone. bubble envelopes are not the proper way to ship plates.
I'll be ready. Sorry to hear about the bending. Damn, if the CF turns up bent, that must've been one hell of a rough shipment.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #729 on: Mon, 05 October 2015, 10:12:54 »
What? CF bent? Please provide some pictures, i packaged it in a cardboard box.
Offline childofthehorn
« Reply #730 on: Mon, 05 October 2015, 10:40:25 »
Anyone know for the RGB Leds for the SpritPCB are 5mm/7mm ? Common Anode or common Cathode?
This is going to be awesome. Also seems like a bunch of us got the Tex acrylic cases for this. Kinda perfect for the sprit PCB.
Offline rpeterclark
  • RPTR ❌
« Reply #731 on: Mon, 05 October 2015, 10:46:38 »
These PCBs do not support RGB LEDs.
Offline Tyr
« Reply #732 on: Mon, 05 October 2015, 11:07:14 »
I read that as: previous plates were bent and now his computer broke so he will have to sell the CF plate when it arrives, presumably for cash to fix the computer.
Offline Jixr
« Reply #733 on: Mon, 05 October 2015, 11:08:03 »
No sorry, i meant that quite often when i buy plates from people they show up bent, often because poor packing. ( just stuffing them in bubble mailers )
CF won't bend, it will just flex till it snaps. I don't have it in hand yet, hoping to get it today.
edited my op for clarity.
« Last Edit: Mon, 05 October 2015, 11:09:34 by Jixr »
Offline trenzafeeds
  • **** off
« Reply #734 on: Mon, 05 October 2015, 13:22:04 »
Do you guys think the plate and sprit pcb will fit in an Eagle case? I know the Duck cases tend to be fairly wonky in terms of screw placement.
demik will never leave.
Unless he gets banned.
Offline trees
  • I like bagels.
« Reply #735 on: Mon, 05 October 2015, 13:23:48 »
afaik it will not.
B.Face HHKB - B.mini - Black/Purple Custom
Offline rpeterclark
  • RPTR ❌
« Reply #736 on: Mon, 05 October 2015, 13:29:18 »
Sprit PCB mounting holes are the same a Poker. Check out these couple of posts where someone asked basically the reverse: https://geekhack.org/index.php?topic=74953.msg1858270#msg1858270, shows the mounting positions of both. At a glance, looks like maybe a few mounts align?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #737 on: Mon, 05 October 2015, 13:30:25 »
Sprit PCB mounting holes are the same the a Poker's. Check out these couple of posts where someone asked basically the reverse: https://geekhack.org/index.php?topic=74953.msg1858270#msg1858270, shows the mounting positions of both though. At a glance, looks like maybe a few mounts align?
OFF TOPIC: Got the SIP sockets. Thanks man
Offline trenzafeeds
  • **** off
« Reply #738 on: Mon, 05 October 2015, 13:33:25 »
Yeah, looks like 4 line up, which IMO is enough to build a steady board.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #739 on: Mon, 05 October 2015, 13:35:01 »
Thats more than enough. I have 2 in my Pok3r
Offline 3K
« Reply #740 on: Tue, 06 October 2015, 11:57:54 »
Today I got my package!
I'm looking forward to put it together  :)
« Last Edit: Tue, 06 October 2015, 12:03:06 by 3K »
Offline Jixr
« Reply #741 on: Tue, 06 October 2015, 12:05:36 »
carbon fiber plate turned out amazing
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #742 on: Tue, 06 October 2015, 12:10:02 »
Thanks for posting!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #743 on: Tue, 06 October 2015, 12:10:18 »
Awesome!
Offline E3E
« Reply #744 on: Tue, 06 October 2015, 12:17:58 »
Haha, damn. Time to wait until the next round pops up! WILL NOT MISS IT. D:
Offline nandop
  • May your keystrokes always be true.
« Reply #745 on: Tue, 06 October 2015, 13:44:31 »
Got my package yesterday, thank you! Dumb of me to assume costar would work based on the pictures but holes were too big. Do you know where I can get good quality stabs in the US?
Sprit 60%, White MX 78g Au | Planck Ortholinear 40% Clear MX | Phantom TKL Browns 110g Au
Offline tofgerl
« Reply #746 on: Tue, 06 October 2015, 13:47:20 »
7bit over on the Deksthority forums has a weird store run out of a forum bot. I think he's in Berlin, though.
Offline Jixr
« Reply #747 on: Tue, 06 October 2015, 15:26:45 »
oooooooh
Sadly it won't work for what i was going to use it for, and I dont' see myself building another 60% anytime soon, so its going to its new home this week.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #748 on: Tue, 06 October 2015, 15:28:19 »
oooooooh
I think the picture link is broken, anyway, I opened it manually.
Awesome! Thanks.
« Reply #749 on: Tue, 06 October 2015, 21:41:47 »
Don't suppose someone has a blue one they'd be willing to sell? Finally found a perfect case to get and begin my 60% journey.
