Author Topic: glue for PBT -- Egypt  (Read 3086 times)
Offline kareemnagi
« on: Sun, 19 July 2015, 06:43:59 »
Hi , my name is kareem from Egypt
im a new member with u fantastic website
plz i need a suitable adhesive for PBT
Online Findecanor
Re: glue for PBT -- Egypt
« Reply #1 on: Sun, 19 July 2015, 06:54:55 »
The most common glues are Cyanoacrylate ("CA glue", "super glue") and epoxy. They work on everything.
People I know use an adhesive called E6000 with plastics, with good results, but I have yet to try it myself: it is easiest to get on eBay.
If you are doing much work with plastics, you sometimes want to use an adhesive with solvents in them - that melt the plastic and then evaporate, allowing the meld to cure. This is called "plastic welding".
These glues are often found in shops that sell plastic model kits and also in building supply stores that sell plastic pipes.
However ... PBT is quite resilient to most solvents. I believe that MEK could dissolve PBT but it is not as common in plastic adhesives as other solvents are.
« Last Edit: Sun, 19 July 2015, 06:59:15 by Findecanor »
Offline kareemnagi
« Reply #2 on: Mon, 20 July 2015, 10:10:52 »
Thank you Findecanor , i appreciated your help but i try MEK and found that it couldn't dissolve PBT
Offline kareemnagi
« Reply #3 on: Sun, 02 August 2015, 07:13:17 »
if i found a suitable solvent for PBT , can i use it as a adhesion in PBT coating ???
