Author Topic: [IC] FingerSK (75% PCB)  (Read 19481 times)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
Re: [IC] FingerSK (75% PCB)
« Reply #50 on: Thu, 06 August 2015, 14:02:43 »
What is the case option for the 75%?
And is there a plate option? And what rgb led is needed?
What I have planned for the cases
  • Same style for both layouts
  • KMAC-Style Case
  • Frosted Acrylic CNC case
  • Acrylic screws
This is to make use of the RGB LEDs that are on the bottom of the PCB. The RGB LEDs come with the PCB AFAIK so you don't have to worry about them.
Offline meiosis
  • Time
« Reply #51 on: Thu, 06 August 2015, 15:06:14 »
August 14th pushes the date past Ivan's RS84 GB... what cases would be compatible with this PCB? I was considering a sprit 75%, if they're even available. Would it fit a Race II case?
The RS items are always available on Taobao (for around the same if not less), We are working on cases, LZ might possibly release a hybrid alu-acrylic case if there is enough demand.
As for Race 2, sadly the USB connector is in a different area
Keyboards:
Aripeko TKL
Offline Data
« Reply #52 on: Thu, 06 August 2015, 15:14:44 »
So this started as a PCB group buy, but now you're only doing cases?
I can't even...   :confused:  <-- major confusion
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #53 on: Thu, 06 August 2015, 15:17:53 »
No. I am offering a case w/ the PCBs, maybe a week or so after this starts.
Offline meiosis
  • Time
« Reply #54 on: Thu, 06 August 2015, 15:19:10 »
Ohh no, everyone on GH wants to have a case made as well on the side, kindly enough Sethk_ has been in the works of getting one, I talked to LZ over possibly a cheaper-designed case for the 75%.
It's solely a PCB GB, no promises on the case, but I am trying to find a solution!
August 14th, will be the start for the PCB gb, with a render and everything.
Keyboards:
Aripeko TKL
Offline Data
« Reply #55 on: Thu, 06 August 2015, 15:20:41 »
OK, thanks for clearing that up for me.   :cool:
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #56 on: Fri, 07 August 2015, 01:21:47 »
I am going to attempt to model the 65% version in inventor pro, but I have no experience in it, so if someone wants to help if I can't do it that would be appreciated  :-[
Offline Norman_the_Owl
« Reply #57 on: Fri, 07 August 2015, 07:34:50 »
Autodesk inventor? I'm pretty decent at inventor...
Offline beltet
« Reply #58 on: Sat, 08 August 2015, 02:33:26 »
  • KMAC-Style Case
  • Acrylic screws
Sry, if I was unclear. I mean the RGB per key. As in Norman_the_Owl's post. What led type is it, seems like some 3 pin type? And what do you need to do with the switches to support this? Because the PCB support it?
Sounds great with the case options!
Thats sounds great! I love the designs I've seen before.
Offline E3E
« Reply #59 on: Sat, 08 August 2015, 09:26:13 »
My not be a bad backup/alternative for my Octagon or an entirely new 75% even. With plate options available, putting a split backspace and other alternate configurations on my Octagon would be way cool.
Offline JonasDK
  • Let me poo on you
« Reply #60 on: Mon, 10 August 2015, 17:09:19 »
The important question is; will it support ISO?
Offline Dreamre
    • kbdlife
« Reply #61 on: Mon, 10 August 2015, 21:12:06 »
  • KMAC-Style Case
  • Acrylic screws
KMAC style and I'm down for one  ;).
Offline Cameron
« Reply #62 on: Sun, 16 August 2015, 04:16:14 »
Can we get a status update since this was planned to go live on August 14?
Offline meiosis
  • Time
« Reply #63 on: Tue, 18 August 2015, 01:41:59 »
Sorry for the delays! Work was pretty hectic, but I have submitted a post for the GB, just need to sort out shipping costs
Keyboards:
Aripeko TKL
