Author Topic: Building a trackpoint-style pointer with this PSP-style joystick?  (Read 3858 times)
Offline mathiasx
    • My Blog
Has anyone tried to use one of these as a "Trackpoint"? https://www.sparkfun.com/products/9426
Just curious -- the teensy should be really easy to hook up for mouse events; I've wired Sparkfun's XBox-controller-style joystick to it before for mouse events.  This looks like it'd fit into a keyboard case a bit better as well as being lower profile and less room needed around it than the XBox controller style joystick.
Offline neverused
Re: Building a trackpoint-style pointer with this PSP-style joystick?
« Reply #1 on: Sat, 29 August 2015, 18:23:17 »
It should work just fine, sometimes I've seen a 10k resistor needed, but it depends. Look up "psp analog arduino" and the principal should be the same.
