Author Topic: Windows 10 Update thoughts and questions...  (Read 183579 times)
Offline katushkin
  • Too Keycool for School
  • Just the guy
Re: Windows 10 Update thoughts and questions...
« Reply #100 on: Wed, 29 July 2015, 22:11:01 »
Login screen is ugly... how to change?  :-[
The background? Or the bit you type the password into? It might change if you use the facial recognition login, but I'm not sure. Packed my webcam away fro the move that never happened lol...
Offline MajorMajor
  • Mechanical Keyboard Enthusiast
    • Coding Supply
« Reply #101 on: Wed, 29 July 2015, 23:21:28 »
Went the automated Windows Update route. Amazed to see no issues, usually I always do a clean install instead, but this is great.
TKL / Clears / Dvorak / Flipped Space for Life / Best Programming Keyboards
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
« Reply #102 on: Thu, 30 July 2015, 04:24:27 »
Has anyone figured out how to turn auto updates off as it kinda bothers me I usually get a terrible ping when I play games 180ms :x and even watching YouTube when play sometimes put me upto 250+
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline baldgye
  • Will Smith Disciple
« Reply #103 on: Thu, 30 July 2015, 04:33:37 »
I believe that there is a way (from Microsoft) to do just that.  I don't have the time ATM to do that.  I will try to find it later.
The only thing I dislike about Windows 10 so far (been using the beta for a while now) is the lack of an option to ignore certain updates. Like graphics drivers. Driver updates should be made "optional" as they have been on all previous versions of Windows. You can only "sort of" turn off automatic updates...meaning you can choose when to restart your PC to apply the updates. I realize this is supposed to be "Windows-as-a-service" and that they want you to have the latest updates at all times. But I really don't need Microsoft updating my graphics driver, when I always get the latest driver direct from Nvidia.
I'm told there is a tool you can download from MS that will change windows updates to work more like win7... but I'm not sure how it works or where you get it from as I've yet to run the OS for any time (tried the beta for a day or so)...
Ah, I hadn't seen that. It's here: https://support.microsoft.com/en-us/kb/3073930
Offline Fire Brand
  • BISCUITS!
« Reply #104 on: Thu, 30 July 2015, 04:51:23 »
Ohh thanks baldgye
Keyboards owned
« Reply #105 on: Thu, 30 July 2015, 05:42:12 »
One of the guys at work received a new notebook couple of days ago with Win 8 on it.
It had the upgrade to Windows 10, and was apparently supported, according to Dell.
He upgraded to Windows 10.
Lots of bits of hardware simply did not work, so he did a factory reset to Win 8.
Offline baldgye
« Reply #106 on: Thu, 30 July 2015, 06:36:37 »
I mean, it's only been out a day. I was pretty surprised that all my hardware worked and had supported drivers. Hell even ATi had proper graphics drivers for x64 win10.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #107 on: Thu, 30 July 2015, 09:00:11 »
I just upgraded to windows 10 on my **** laptop, and it has been quite nice so far. much smoother than windows 8 was...
Oh and the new internet explorer is actually quite nice surprisingly. It's quite fast and pretty sleek looking...
« Last Edit: Thu, 30 July 2015, 09:01:46 by Air tree »
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #108 on: Thu, 30 July 2015, 12:37:09 »
The Surface Pro 3 was upgraded last night and seems to have gone well. I liked earlier versions of Windows 10 visually more, but it seems like what we wound up ain't too bad.
So far it's running as smoothly as 8.1, which is great.
Now if I can get my work to move on from Windows 7...
Offline TastaturenAuslese
  • Formerly temence
  • life marrow suckerer
« Reply #109 on: Thu, 30 July 2015, 13:13:38 »
Anyone having troubles with games in Windows 10? Or do I have nothing to fear?
Home: Kishsaver - IBM 6019284/F62 | Work: HHKB Professional 2 Silenced | Temporary Retirement:
IBM '89 1391401 Merrill Lynch Financial Edition
They are a functional and practical indulgence.
Offline baldgye
« Reply #110 on: Thu, 30 July 2015, 13:21:06 »
I was worried but after installing the gfx drivers I ran all the games I've been messing with recently;
Project Cars
Starcraft 2
Alien Isolation
and all ran as they did in win7, even my settings where the same
  • Formerly temence
« Reply #111 on: Thu, 30 July 2015, 13:34:21 »
Project Cars
Starcraft 2
Alien Isolation
Are GFX drivers = Graphics card drivers? :3
« Reply #112 on: Thu, 30 July 2015, 13:35:11 »
Inability to adjust window/start menu colors is a bit lame  :(
It's running alright, but it just seems like the UI was rushed.
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #113 on: Thu, 30 July 2015, 14:19:38 »
Which is hilarious since they've been tweaking it for nearly a YEAER.
I did like the look of Windows 8.1 a lot more, generally.
« Reply #114 on: Thu, 30 July 2015, 14:35:47 »
What's there to tweak?  It's super minimal, all tiles, but lacks customization and everything is spread out ERREWHERE.  It's like... the larger my screen the more movement I need to do with my mouse to use stuff.  Bing integration with search/run is a terrible idea.
Offline katushkin
  • Just the guy
« Reply #115 on: Thu, 30 July 2015, 14:53:41 »
I've had a lot of network issues, but that could be coincidental. A friend at work discovered Kaspersky wasn't working so downloaded some new software. An hour later Kaspersky updated to be compatible hah.
As for the UI, I don't think it's been rushed. I don't think stuff is spread out, unless you mean the settings are all in new places, it seems like it's the same areas on the screen it was in Windows 7, unless there are things I'm not using. Scrolling down in the start menu is cool, and I don't mind the blue start menu. I don't tend to spend a lot of time with it up for it to make a notable impact on my colour scheme.
The only thing I am a bit annoyed at is when you have a blank page set to open when you open a new tab, you have to click in the address box before you type anything in, instead of just putting the typing prompt in there straight away.
Offline Lord of Narwhals
  • You can call me NaLo
    • A selection of posts chosen with care, prior to remembering your indifference to them.
« Reply #116 on: Thu, 30 July 2015, 15:04:06 »
Edge seems like a pretty good browser but I can't move away from my Chrome extensions (especially Vimium).
Hopefully itwill give Google an incentive to optimize Chrome though because right now it just eats RAM.
In the end.. the keyboard's most grand form of existence is as an ethereal bridge between man and machine..    Each depression of the keys, evanescent.. Our transitory thoughts crashing into the web, carving canyons through the internet wasteland such that life may once again flourish..
HHKB Pro 2 Poker II [MX Red]
Offline katushkin
  • Just the guy
« Reply #117 on: Thu, 30 July 2015, 15:05:37 »
Yeah, RES and my picture viewer are quite annoying to be without. I also can't use the web version of whatsapp on IE for some reason =/
Offline slip84
  • GUYDUDE MAGICIAN
« Reply #118 on: Thu, 30 July 2015, 15:26:08 »
Chrome noms RAM by design. You have a messload of tabs open? RAM = gone.
Google has a page about this: https://support.google.com/chrome/answer/6152583?hl=en
Offline Ryukuxyz
  • VE.A!!!
« Reply #119 on: Thu, 30 July 2015, 20:45:10 »
Finally got it installed last night, been using it the whole day and I must say it's pretty pleasing to use.  Everything worked perfectly after the install, EXCEPT the NVidia drivers, which was fixed by simply deleting the old drivers, and installing the new ones from NVidia's site.  Overall the UI is very pleasing, though it's going to take a bit to get used to not being able to mouse to the side of my screens for window selection and volume/power options.  The notification thing they added is pretty nice, but I think I'm going to disable the option to automatically update.  The new browser they added, Edge, is extremely snappy; it literally opens the instant I click it, no delay whatsoever.  I will most likely use it for Netflix and streaming services, but stick with Opera for regular browsing.  The taskbar icons are kind of small, which is a bit annoying, and the big "Search Windows" bar is as well, but I'm sure with a bit of research I'll be able to fix these things up as well.  The biggest thing I liked about this new OS is the start menu, I personally did not like the Win8 one at all, and in Win10 they switched back to a more Win7/Vista-esque traditional taskbar, which I love.  Overall, the experience is great so far, I would definitely recommend upgrading if you are able to, just make sure to disable all the "botnet" stuff like keystroke logging.
Offline katushkin
  • Just the guy
« Reply #120 on: Thu, 30 July 2015, 20:49:46 »
I don't understand the reason why you would want to turn off the automatic updates...
Offline Ryukuxyz
  • VE.A!!!
« Reply #121 on: Thu, 30 July 2015, 20:53:46 »
The only reason I'm turning them off is because it forces a restart, and if I'm in the middle of something important and it does it, I'd get pissed.   I checked for updates weekly manually back on Win8 anyways, so I won't be too outdated anyways.
Offline katushkin
  • Just the guy
« Reply #122 on: Thu, 30 July 2015, 20:59:30 »
I am pretty sure they aren't going to force a restart upon you without notifying you.
« Reply #123 on: Thu, 30 July 2015, 21:15:44 »
Oh but it does :3
« Reply #124 on: Thu, 30 July 2015, 21:24:13 »
Do you think that updates will come out more often or random than (not every) Tuesday afternoons?
- D Trump 2026-10-24
Offline katushkin
  • Just the guy
« Reply #125 on: Thu, 30 July 2015, 21:31:30 »
Oh but it does :3
What? Just, all of a sudden; restart?
« Reply #126 on: Thu, 30 July 2015, 22:00:30 »
Oh but it does :3
si capitan.  I do get a notification, but once it's done installing.... WHOOP restart.
Offline Ryukuxyz
  • VE.A!!!
« Reply #127 on: Thu, 30 July 2015, 22:04:00 »
Oh but it does :3
Yup, I've been restarted on twice now, already disabled automatic updates.  Like I said, it's no big deal, I check once a week anyways, so I won't be missing anything.
Offline katushkin
  • Just the guy
« Reply #128 on: Thu, 30 July 2015, 22:44:49 »
Well that's stupid.
« Reply #129 on: Thu, 30 July 2015, 22:47:21 »
Well that's stupid.
There's lots of "wtf" with this OS.  Like I said it runs great but.... wtf UI?  Common sense settings/admin functions/updates? NON-SENSE!
« Reply #130 on: Thu, 30 July 2015, 22:52:00 »
Well that's stupid.
Welcome to Microsoft mentality.
Offline katushkin
  • Just the guy
« Reply #131 on: Fri, 31 July 2015, 00:29:49 »
Some useful keyboard shortcuts for those who haven't got rid of their windows keys:
Winkey + Tab Activates Task View
Winkey + A Activates Action Center
Winkey + C Activates Cortana with speech>
Winkey + D Shows desktop
Winkey + E Opens File Explorer
Winkey + G Activates the new Xbox game bar to let you record games or take screenshots.
Winkey + H Activates share feature in Windows 10 apps
Winkey + I Opens Windows 10 settings
Winkey + K Activates Connect feature to stream to wireless displays and audio devices
Winkey + L Locks a machine
Winkey + P Project a screen
Winkey + R Run a command
Winkey + S Activates Cortana
Winkey + X Opens power user features
Winkey + Left / Right / Up / Down Snaps apps to the side of a screen (press Up or Down after snapping left / right to enable four apps to snap)
Winkey + Ctrl + D Creates a new virtual desktop
Winkey + Ctrl + F4 Close virtual desktop
Winkey + Ctrl + Left or Right Switch between virtual desktops
Winkey + Shift + Left or Right Move apps from one monitor to another
Winkey + 1 / 2 / 3... Open programs that are pinned on the taskbar. The first app is number one.
Offline njbair
    • nickbair.net
« Reply #132 on: Fri, 31 July 2015, 00:40:32 »
Does right-clicking the start button still bring up that nice context menu to access admin stuff?
My boards:
Offline baldgye
« Reply #133 on: Fri, 31 July 2015, 01:08:27 »
Well that's stupid.
I really like the new UI, though I'm still getting used to the new start menu
Offline Fire Brand
  • BISCUITS!
« Reply #134 on: Fri, 31 July 2015, 03:35:32 »
Oh but it does :3
Yeah I can confirm I had it happen just yesterday was happily playing league of legends mid game, then blam restarting was not impressed :I
Also just updated my Alienware laptop and after a bit of fiddling with the sound drive everything is work fine :)
Keyboards owned
« Reply #135 on: Fri, 31 July 2015, 04:45:41 »
To turn off random restarts:
Settings -> Update & Security -> Windows Update -> Advanced Options -> Change it from "Automatic" to "Notify to schedule restart"
« Reply #136 on: Fri, 31 July 2015, 05:33:42 »
Something happened.
Offline Belfong
« Reply #137 on: Fri, 31 July 2015, 08:32:53 »
yes it does and more.
Offline fishcola
« Reply #138 on: Fri, 31 July 2015, 10:51:32 »
I wish the settings page was smaller and more space efficient. It feels too spread out. I hope MS makes a more space efficient one... this one seems like a lazy approach to covering touch and non-touch devices.... Wierd how control panel follows the traditional layout but it feels like someone dropped a grenade in settings.
Offline njbair
    • nickbair.net
« Reply #139 on: Fri, 31 July 2015, 11:17:40 »
My boards:
Offline baldgye
Offline Ryukuxyz
  • VE.A!!!
« Reply #141 on: Fri, 31 July 2015, 11:41:01 »
Well that's stupid.
I really like the new start menu, it feels more like an actual start menu rather than a weird panels thing.
« Reply #142 on: Fri, 31 July 2015, 11:46:34 »
Well that's stupid.
Coming from W7 there isn't much that's improved in the start menu.
Offline baldgye
« Reply #143 on: Fri, 31 July 2015, 12:36:05 »
Well that's stupid.
I kinda know what you mean, but the tiles have a lot of room to grow and add to the start menu, having more info you can quickly glance at while not taking up the desktop is nice.
I also really like the notifications area in the task bar
« Reply #144 on: Fri, 31 July 2015, 12:37:55 »
Well that's stupid.
Is there a shortcut for notifications? clicking in the lower right of my monitor is sort of a stretch.
Offline baldgye
« Reply #145 on: Fri, 31 July 2015, 12:41:07 »
Well that's stupid.
I've no idea, Kat posted a keyboard shortcut list a page or two back, but I'm just a one screen povo so it's not something I ever thought about haha
« Reply #146 on: Fri, 31 July 2015, 14:41:47 »
« Last Edit: Fri, 31 July 2015, 14:46:50 by jdcarpe »
Offline njbair
    • nickbair.net
« Reply #147 on: Fri, 31 July 2015, 15:27:42 »
Something happened.
Somebody set up us the bomb.
It was Microsoft.
What you say!!!
Seriously though, I finally got Windows 10 installed on my work computer. So far it's not very different from 8. I like having the start menu back. Other than that, I immediately disabled anything Bing-related and moved my tiles back where I wanted them.
My big concern is whether or not this will be a welcome change for my staff who are all still on Win7 and don't want to move off of it.
My boards:
Offline Fire Brand
  • BISCUITS!
« Reply #148 on: Fri, 31 July 2015, 15:38:46 »
They have no choice ^~^
Also why do you not have the title "It's so bad" Yet? hoff get on this!
Keyboards owned
« Reply #149 on: Fri, 31 July 2015, 15:49:25 »
Just did the free upgrade from 7. I was on 7 because I hated 8. So far Im digging 10! :)
