Author Topic: Windows 10 Update thoughts and questions...  (Read 183578 times)
Offline Leslieann
Re: Windows 10 Update thoughts and questions...
« Reply #600 on: Mon, 17 April 2017, 17:24:32 »
My main windows 10 PC after it updated this weekend is almost unusable to browse the web.
It works in ~25-30 second intervals then freezes for 5-10 seconds then works.... :confused:
I would never touch Win again (except for gaming) if it weren't for the fact I REALLY NEED MS Office for work (and SPSS only runs semi-decent on win, it drags on os x and linux). Oh and lightroom, illustrator, and photoshop. There are no really good substitutes for those in linux still. Such a shame. AND DON'T TELL ME INKSCAPE AND GIMP.
Wine has actually made some major leaps recently, so you may want to try.
Lightroom, Photoshop and Illustrator run just fine through Wine or (even easier) PlayOnLinux, I can vouch for the latter two (I'm with you regarding GIMP!).
Office, is kind of iffy, depending on version and exact program, but in general it seems to work just fine.
SPSS, some versions seem to run great, others, no so great, however there is an open source replacement called PSPP. Note, I don't know anything about either of these programs, it just came up when I checked for SPSS.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline iLLucionist
  • Topre is Love.
« Reply #601 on: Mon, 17 April 2017, 17:29:02 »
Thanks! Now this is all great on a workstation, so I should try it out on my ubuntu VM first.
However, how taxing is wine on battery life? Would running office / adobe over wine significantly reduce my battery life? Coz if not we have a winner here.
I'm wondering whether the next version of Office will check for telemetry code in the OS and if not found crashes or errors. So that wine has to implement or fake "telemetry".
« Reply #602 on: Mon, 17 April 2017, 17:29:40 »
Spss ? what are you n00bs..   Stata is where it's @
Offline iLLucionist
  • Topre is Love.
« Reply #603 on: Mon, 17 April 2017, 17:32:17 »
Can't. Tried to switch to R as well, no issue for me, being a real programmer. But colleagues don't understand it. They can barely understand SPSS syntax, let alone a "real" programming environment like Stata or Mathematica.
I once had to run a ton of exploratory analyses on a dataset. I switched to python to automate it. Was less work in the end, just iterate over all possible combinations of IV, moderator/mediator, DV, etc. run regressions automatically. I just could not explain it to colleagues. Perhaps that's my fault, I don't know.
SPSS is the currency in my business, as is Word.
Offline Leslieann
« Reply #604 on: Mon, 17 April 2017, 18:26:50 »
You're welcome.
Office 16 and 365 pretty much rolls right into Win10 and telemetry which is why they push it so hard. In fact if you install Office 2013 one Win10, Windows ignores that you installed it and keeps trying to push newer versions on you. Instead of checking for telemetry, it's more likely they will "accidentally" break support for older versions prior to the latest. They promise support for Office for x number of years, they never promise forward compatibility beyond what was on the box.
The other thing they could do is death by 1000 cuts, start slowly breaking older versions a little at a time, pushing people to finally bite the bullet and update. Odds are that will happen anyway as many people using Office have this idea that they always have to be current.
I don't know about WINE in regards to battery, however, it shouldn't impact it as WINE isn't emulating Windows, it's running Windows as as native apps.
What you will want to do though is tune your power management. Windows throttles processors to 50% when on battery, whereas Linux doesn't by default (as far as I can tell). Installing Intel Pstate and TLP, then using TLP to throttle the processor to 50% while on battery will get your battery life back close to what it got while on Windows.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline digi
  • elite af tbh
  • keyboard game on fleek
« Reply #605 on: Mon, 17 April 2017, 18:29:56 »
My recommendation is to stay with Windows 7 64 Bit!
Offline iLLucionist
  • Topre is Love.
« Reply #606 on: Mon, 17 April 2017, 18:33:00 »
You're welcome.
Thanks, this is very useful info!
Offline iLLucionist
  • Topre is Love.
« Reply #607 on: Mon, 17 April 2017, 18:33:53 »
Yes and no -- the f**kers backported telemetry to win 7 via updates. There was a certain date (google it) up to where there was not telemetry but after that date the updates also included the backported telemetry.
Offline Leslieann
« Reply #608 on: Mon, 17 April 2017, 18:39:42 »
July 2015 saw the first bits of telemetry in Win7 and 8 updates.
There are lists of what updates you can and can't install to avoid it, however MS is putting an end to that as well with the new update system.
There are updated copies you can download with those bits removed, however you need to put your faith in some random person online (some are trustworthy). Legally these fall into a gray area.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline digi
  • elite af tbh
« Reply #609 on: Mon, 17 April 2017, 19:08:49 »
well damn...they're gonna see all my Amazon purchases now.
« Reply #610 on: Mon, 17 April 2017, 19:55:07 »
I'm still using office 2007.
Offline fanpeople
« Reply #611 on: Mon, 17 April 2017, 19:57:31 »
MY WORKPLACE IS USING THE 2003 version... OH WAIT WE JUST UPGRADED TO 2007
« Reply #612 on: Mon, 17 April 2017, 20:50:42 »
Tp4 still uses 2003..
But I also haz 2007 because of docx.
Offline iLLucionist
  • Topre is Love.
« Reply #613 on: Tue, 18 April 2017, 03:26:38 »
I take it you probably don't just by books there hehehe
Offline iLLucionist
  • Topre is Love.
« Reply #614 on: Tue, 18 April 2017, 03:27:38 »
We have 2010? Or is that 2007? The one before 2016 at least at the office.
And it sucks. Font rendering is SO HEAVY. Painful on the eyes. Especially Times New Roman.
Offline Leslieann
« Reply #615 on: Tue, 18 April 2017, 16:08:17 »
2013 was just before 2016.
3 year cycle.
2003 I think was the best variant, after that they messed the menus up and hid a lot of what I use.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
| Das Pro
| GH60
Offline iLLucionist
  • Topre is Love.
« Reply #616 on: Tue, 18 April 2017, 16:11:32 »
3 year cycle.
I don't see much improvement after 2001 Platinum.
1997 was a bit too crashy with tables and layout constantly messed up with pictures (and I know how to format properly).
2001 was the sweet spot. The rest after was really just marketing.
Offline digi
  • elite af tbh
« Reply #617 on: Tue, 18 April 2017, 16:13:30 »
Noooo, I buy woks and wok burners too, vegetables so fresh with Amazon Fresh, I don't have to go anywhere!!! yess
« Reply #618 on: Tue, 18 April 2017, 17:11:33 »
Careful digi,  they can see ur amazon Alt-account too...... hahahahahahhaa. the one u use for all the naughty stuff..
