Author Topic: Does such a plate already exist?  (Read 2392 times)
Offline ishpeck
  • Life without MX Blues is no kind of life at all.
    • The Ishpeckian Network
« on: Tue, 21 July 2015, 08:28:40 »
I'm wanting to build an ortholinear board with a series of 1.25u keys on the bottom row...
I was about to sit down and force myself to learn how to use CAD software but I realize this doesn't seem all that unique of an idea and it may be that somebody's already built such a plate.  So I figured I'd ask.
0:=λfx.x
Re: Does such a plate already exist?
« Reply #1 on: Tue, 21 July 2015, 08:29:34 »
Not quite as small as your layout but you might find something interesting here http://www.ortholinearkeyboards.com/
« Reply #2 on: Tue, 21 July 2015, 08:40:33 »
Offline ishpeck
« Reply #3 on: Tue, 21 July 2015, 08:41:33 »
Oh, hey!
I'd looked at their plates and found nothing quite the way I wanted -- BUT!!! -- just now, I noticed that they do custom plates and take Keyboard Layout Editor links... ?
This what I think it is?
0:=λfx.x
Offline ishpeck
« Reply #4 on: Tue, 21 July 2015, 08:44:49 »
Here you go...
Tools used:
http://www.keyboard-layout-editor.com/#/layouts/f5d8de17ba31589082d6186413247681
http://builder.swillkb.com/
You're my hero.
I will build a shrine to you.
Which type of switch should this shrine employ?
0:=λfx.x
« Reply #5 on: Tue, 21 July 2015, 08:45:55 »
Here you go...
Tools used:
You're my hero.
Haha, Gateron Black, of course. :P
Offline ishpeck
« Reply #6 on: Tue, 21 July 2015, 09:06:29 »
This is awesome!
Does the DXF file have dimensions specified in it somewhere?
0:=λfx.x
« Reply #7 on: Tue, 21 July 2015, 09:09:19 »
This is awesome!
It should, in millimeters. I forget what swill said about how to specify that to the plate cutter.
