Author Topic: Workrave  (Read 4248 times)
Offline d2v
Workrave
« on: Mon, 05 October 2009, 12:02:00 »
I use workrave on my computers, for typing break reminders. What such software do you guys use, if you use any ?
DSI SMK-88 (Black cherry), TVS Gold, Kensington Expert Mouse, MS NEK 4000, MS NWM 6000
Offline wellington1869
Workrave
« Reply #1 on: Mon, 05 October 2009, 14:22:44 »
i've tried eyedefender and 'take a break'. Liked them both.  The former makes you exercise your eyes during your break via images on the computer screen. The latter has some handy features like deferring your break for another ten minutes with a click.
http://download.cnet.com/EyeDefender/3000-2124_4-10870338.html?tag=mncol
http://download.cnet.com/Scirocco-Take-a-Break/3000-2350_4-10333152.html?tag=mncol
using: ms 7000/Das 3
Offline Rajagra
Workrave
« Reply #2 on: Mon, 05 October 2009, 14:37:44 »
I might try workrave.
I think I tried eyedefender a long, long time ago but it just bugged me and got uninstalled quickly.
Offline d2v
Workrave
« Reply #3 on: Mon, 05 October 2009, 20:25:09 »
Quote from: wellington1869;123178
Workrave also has two break levels - called Micro Break (default interval between breaks is 4.5 minutes) and Rest Break (default interval is 30 minutes, iirc). The breaks can be deferred for a few minutes. Also, if one goes enough time without using mouse/keyboard, the time to next interval automatically resets. (workrave calls it natural break)
During the rest break it will show you exercises for eyes and arms. The exercises can also be accessed at any time by right clicking on the tray icon.
The best bit is the statistics records, which shows the number of mouse clicks, number of keystrokes and total mouse travel distance per day.
Workrave also has the ability to synchronize the timers on multiple machines that you use simultaneously, and are networked. I couldn't get this part to work without crashing workrave.
Link to website
« Last Edit: Mon, 05 October 2009, 20:27:00 by d2v »
Workrave
« Reply #4 on: Mon, 05 October 2009, 20:33:37 »
Quote from: d2v;123280
thats a good feature.
i'll try it out :)
Offline Rajagra
Workrave
« Reply #5 on: Mon, 05 October 2009, 20:51:11 »
I installed it and it seems to have defaulted to 3 minutes, but even that isn't too annoying. During the short breaks I can take off my glasses to rest my eyes.
It confused me at first when I tried to click on the popup box and it kept 'running away' LOL. Either ignoring it or stopping work seems to be the 2 ways to respond.
