Author Topic: What Apps do you use to take better pictures with your phone  (Read 3672 times)
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« on: Wed, 22 July 2015, 17:35:51 »
I want to be able to take better pictures with my iphone. I have seen some amazing shots done with the iphone but I cant ever replicate the same effect.
Re: What Apps do you use to take better pictures with your phone
« Reply #1 on: Wed, 22 July 2015, 17:46:08 »
It's more a case of lighting.  The better lighting you have, the better pics you can take.
Offline Bromono
  • Wanabe Cicerone
« Reply #2 on: Wed, 22 July 2015, 17:59:04 »
hmm, maybe I should get a tiny light booth
Offline fliptrik
« Reply #3 on: Wed, 22 July 2015, 18:06:48 »
You could look into picking up a softbox in order to give you some nice light. Or a reflector if shooting outside. They have kits on Amazon for pretty cheap that you'd be able to snag.
Offline Axollott
« Reply #4 on: Wed, 22 July 2015, 18:24:05 »
I use A Better Camera (Android) for taking pictures, mostly in HDR and it gives me the option to save the original exposure bracketed files which i can then edit in the computer. If i don't mind so much or need to send the picture immediately i pass it through Anandtech Perfectly Clear for quick enhancements. That's it.
« Reply #5 on: Wed, 22 July 2015, 21:43:33 »
Such a contraption seems to make a huge positive difference to photos taken here, especially keycaps, which are by definition very small, and even keyboards.
Some people have even made their own out of a simple wooden frame and some old white bed sheets.
Offline baldgye
  • Will Smith Disciple
« Reply #6 on: Thu, 23 July 2015, 02:58:26 »
This is an amazing post, for a couple of reasons:
1. Android is an OS not a phone.
2. The iPhone 6 and 6+ has a much better camera than nearly all Android handsets.
3. The rest of what you described can be done on an iPhone and has been a feature of them for years.
Like everyone else has said with a brain, light is a huge deal. I can take some pretty damn good shots outside in the sun when the weather is perfect, but inside in middling light it struggles like mad. The default camera app gets the most out of the lense and sensor of the phone, other apps just add the ability to slap on fancy filters which don't actually improve the image.
Offline jerue
  • (Whenever that happens :P)
« Reply #7 on: Thu, 23 July 2015, 08:02:31 »
This. There is great post processing software like Camera+ , but lighting is really the only aspect you can control when taking photos on the iPhone (shutter speed and aperture are pretty much determined out of the box).
Offline Axollott
« Reply #8 on: Thu, 23 July 2015, 08:38:55 »
You are unzipping your pants way too soon and your brain is spilling out of them.
1.- A Better Camera
https://play.google.com/store/apps/details?id=com.almalence.opencam
2.- The rest are just assumptions based on the misunderstanding of what A Better Camera (*for* Android) meant.
Offline Jokrik
« Reply #9 on: Thu, 23 July 2015, 08:41:43 »
I use VSCO to edit my pictures on the go
Even when I transfer photos wirelessly from my X100T
but to take good photo you need a good phone with good camera to begin with, and good lighting as people above has said
Offline baldgye
« Reply #10 on: Thu, 23 July 2015, 13:27:56 »
1.- A Better Camera
Assumptions? Nope just read your post, hardly my fault if you struggle with sense structure or the placement or words.
Though it should also be pointed out that you recommended an android app when the OP pretty clearly states he's using an iPhone... But yes, I'm letting my brain spil out of my pants, on the off chance you might pick something up from the spillage.
« Last Edit: Thu, 23 July 2015, 13:38:32 by baldgye »
