Author Topic: Unicomp Classic Bent Spring  (Read 2191 times)
Offline Pspboy17
« on: Thu, 23 July 2015, 15:51:23 »
I had to remove my enter key today to grab a paperclip that got stuck on the side. As I put the key back on the spring got stuck somehow and got bent  :(. Is there an easy way I can fix this? The keyboard is out of warranty and I don't know what Unicomp charges for repairs.
The world needs more CRT's
  • Live long and prosper
Re: Unicomp Classic Bent Spring
« Reply #1 on: Thu, 23 July 2015, 15:54:32 »
chopstick method
insert chopstick into spring hole and bend spring back into shape
http://imgur.com/a/6bnzW
if bending proves difficult, order another spring from Unicomp (will be dirt cheap) and do a complete spring swap using this same method
« Last Edit: Thu, 23 July 2015, 15:57:26 by Computer-Lab in Basement »
tp thread is tp thread
Offline Pspboy17
« Reply #2 on: Thu, 23 July 2015, 16:00:47 »
I had no idea they were removable, I'm gonna try this. Thank you very much!
« Reply #3 on: Thu, 23 July 2015, 16:03:42 »
they're not supposed to be, but if this is done properly that can be removed and replaced without much trouble
Offline Pspboy17
« Reply #4 on: Thu, 23 July 2015, 16:07:37 »
Well, here's the victim. The replacement assemblies for the keys are $.20, so I'm happy there. Could I temporarily steal the key from pause|break?
Offline Wildcard
  • When caffeine isn't enough
« Reply #5 on: Thu, 23 July 2015, 16:13:00 »
chopstick method
I really enjoy Ripster's posts. Good times.
Offline Pspboy17
« Reply #6 on: Thu, 23 July 2015, 16:20:07 »
Thank you so much, I have an Enter key again  ;)
