Author Topic: Some professional soldering stations  (Read 2390 times)
Offline Parak
« on: Fri, 24 July 2015, 01:36:54 »
In case you solder a /lot/ and actually want something of higher quality than normal with better tip choices:
http://www.ebay.com/itm/161772208518
http://www.ebay.com/itm/281757077819
http://www.ebay.com/itm/281757070978
The hakko is okay, but in terms of actual thermal recovery, heat up time and ease of use the Metcals win (but at a higher price). Typical tips for either are somewhere around $10-$15.
Datasheet for the Oki: http://www.farnell.com/datasheets/12273.pdf
Offline XMIT
  • formerly jsoltren
Re: Some professional soldering stations
« Reply #1 on: Fri, 24 July 2015, 06:01:41 »
I use a Weller WES51. Great bang per buck. It's what my college had in the electronics labs.
I've got my eyes on a professional vacuum desoldering station now.
Offline Touch_It
« Reply #2 on: Fri, 24 July 2015, 16:07:05 »
I need to get one down the road sometime.  I've used cheap walmart and radioshack irons and they are ****.  I borrowed some older weller iron from work and even with that the difference was night and day.  I was quite surprised.  seems these sold quick.
Offline REVENGE
« Reply #3 on: Sat, 25 July 2015, 05:15:38 »
I just used and returned a ZD-985. It's a very useful tool, but be prepared to do a lot of annoying servicing of the heating element / nozzle.
Offline Parak
« Reply #4 on: Sat, 25 July 2015, 14:49:21 »
If you have access to a compressor, it's hard to do better than a Metcal MX-DS1 handpiece for desoldering. The top end stations that it comes with are the MX-5251 and MX-5250, but they're not for the faint of heart in terms of cost. Without a compressor, you'd probably be looking at a Pace ST115 or similar, which also usually runs a nice chunk of change but as a bonus allows for a decent hot air option too.
