Author Topic: Medical study?  (Read 2451 times)
Offline Hakhu
Medical study?
« on: Tue, 06 October 2009, 05:49:36 »
Do you know of any medical surveys or studies that prove the superiority of mechanical switch keyboards or rather the stress put on fingerjoints from using rubber-dome switches?
Thanks ...
Offline Hakhu
Medical study?
« Reply #1 on: Tue, 06 October 2009, 06:29:20 »
Or any other studies for that matter, scientific studies, that show the superiority of mechanical switches.
Ergonomic, typing speed, error rate etc.
Offline Rajagra
Medical study?
« Reply #2 on: Tue, 06 October 2009, 06:59:44 »
I found this.
Cases generated significantly higher keyboarding forces than controls, although both groups produced forces well above that required to operate the keyboard (4-5 times activation force). Cases reported higher levels of upper extremity symptoms and discomfort than controls, and these measures were highest after the keyboarding task for both groups. No significant correlation between keyforce and key rate was observed in either group. Results suggest that generation of excessive force while working on a computer keyboard may contribute to the severity of upper extremity symptoms.
Does suggest that the key's activation force is not an issue, but bottoming out hard is a big problem.
And we all know what type of switches demand that you bottom out.
Offline hyperlinked
Medical study?
« Reply #3 on: Tue, 06 October 2009, 09:53:49 »
Quote from: Rajagra;123380
I found this.
Ergonomics is a really messy area of practice. One article, especially just an abstract isn't enough to really cite as evidence. There are a number of problems with that study right from the start. Any study that's using self report of pain, distress, and discomfort as a critical measure for their study is already working from behind as people have very different levels of tolerance of physical discomfort and have very different perceptions of what maximum and minimum pain is. Two people can report that they're in so much pain that they don't know how much longer they can keep doing the task you ask them to do, yet one of them may continue for another hour while the other one stops immediately thereafter. Pain reports are totally unreliable unless they're qualified by other data.
I'm curious what the "Composite Symptom Severity" score is and how it's compiled. I'm not familiar with that assessment tool.
There's also no data about the working envioronments between the cases and controls (at least not in the abstract). They may have all been using rubber domed keyboards or they may all have been using mechanical keyswitches.
The kind of upper extremity symptoms and measurses they used would also be relevant to evaluate the soundness of these findings. If they're using a generalized pool of symptoms, then a study size of 48 is a tiny sample size from which to be drawing any definitive findings from.
There are also numerous studies that suggest the speed of typing may be an event bigger factor in injury risk than any kind of force generated by the typing itself whether from key activation or from bottoming out.
« Last Edit: Tue, 06 October 2009, 10:18:26 by hyperlinked »
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
