Author Topic: Where to go next?  (Read 3341 times)
Offline trees
  • I like bagels.
Where to go next?
« on: Fri, 24 July 2015, 09:19:54 »
Alright guys, I normally like to give help when people don't know what to buy, but this time I'm asking for it.
After using and testing a bunch of key boards, I have set my 2 current daily drivers, a HHKB & a FC660C. I love them, 45g Topre is great but now I'm looking for my next venture.
I have around 250-300$ or so. I was considering:
  • an SSK
  • possibly try 55g topre with a realforce
  • I saw you can order completely custom boards from winkeyless's website (would go over my 300$).
  • attempt to build one
  • Get a PCB/Parts and have someone build one for me (I don't own soldering equipment, and don't have the steadiest hands)
  • join a GB of some sort of keyboard
What do you think? What fun new mech type experience should I go with next? I'm not too picky, I only really don't like browns or super heavy switches, and would prefer TKL or smaller.
B.Face HHKB - B.mini - Black/Purple Custom
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
Re: Where to go next?
« Reply #1 on: Fri, 24 July 2015, 09:29:09 »
I just got myself a 55g HHKB Type-S and a 55g 23U and I love them. My next board I plan on getting is something with clears. Will most likely be a 75% board or a 1800 type board. I also have my eye on Ellipse's custom F62 and F77 IC.
Offline trees
  • I like bagels.
« Reply #2 on: Fri, 24 July 2015, 09:39:50 »
My next board I plan on getting is something with clears. I also have my eye on Ellipse's custom F62 and F77 IC.
The one cherry switch i never tried was clears, but i think they may be too heavy for me (i thought blacks were overly stiff). I would love to use something with ergo-clears.
I'm watching Ellipse's thread as well, but I've never used BS before. How are they?
Offline jerue
  • (Whenever that happens :P)
« Reply #3 on: Fri, 24 July 2015, 09:40:20 »
I'd go for the 55g Realforce. I picture the SSK feeling rather similar to the Model M (smaller form factor would mean lighter, but still), and most custom boards will definitely go over your budget. You could probably get the Realforce and a Model M for within your budget.
    • WTB/WTTF Thread
« Reply #4 on: Fri, 24 July 2015, 09:42:29 »
I need to order some stock cherry clears as well to see and then possibly mod them to ergo clears.
I have never used BS boards before but figure I might as well go off the deep end and grab one as they look like they will turn out to be great boards. I just hope it comes to fruition.
Offline trees
  • I like bagels.
« Reply #5 on: Fri, 24 July 2015, 09:47:40 »
How much stiffer is the 55g domes compared to the 45? I know the '10g' is obvious, but how is it real world, as someone who wasnt a fan of stiffer cherrys for being too heavy, is that going to be an issue?
« Reply #6 on: Fri, 24 July 2015, 09:51:11 »
Do you have a Microcenter near you? You can try the Novatouch there and figure it out for yourself.
Offline trees
  • I like bagels.
« Reply #7 on: Fri, 24 July 2015, 09:54:05 »
I owned and just recently sold a Novatouch and it had 45g domes?
Offline Lurch
« Reply #8 on: Fri, 24 July 2015, 09:59:28 »
I would go with a Model F resto over a SSK or 55g RF. ;D
Quote from: Flyersfan1
« Reply #9 on: Fri, 24 July 2015, 10:01:50 »
Thought it had 55g my bad.
Offline fishcola
« Reply #10 on: Sat, 25 July 2015, 18:51:31 »
Just a thought, but if you're still curious about clears, you could pick up a KUL ES-87 and save towards something grander in the future?
Offline pr0ximity
« Reply #11 on: Sat, 25 July 2015, 19:26:50 »
Depends on how deep you want to go into BS land. If you're serious about that, I highly recommend grabbing an F. There's a 107-key 4704 on eBay for $250 right now that just needs an xwhatsit to work with USB, f you have the interest. It's huge but imo it's difficult to get much better in terms of tactile, clicky switches. Full die-cast aluminum case, so the free shipping is key  :p
Otherwise, 55g Realforce, since you seem to be really into Topre.
« Reply #12 on: Sat, 25 July 2015, 20:38:17 »
55g RF
« Reply #13 on: Sun, 26 July 2015, 03:00:52 »
If you like Topre, then 55g RF, although using 55g might spoil you for the HHKB and FC660C.
Or SSK if you want to try something completely different.
Offline TastaturenAuslese
  • Formerly temence
  • life marrow suckerer
« Reply #14 on: Sun, 26 July 2015, 20:54:12 »
If you don't like heavy switches, I wouldn't suggest going with an SSK. It's quite stiff, ~70g or something I've read? And yes, they feel a lot stiffer than my HHKB.
I'd recommend Ergo Clears. I love my Model M at home, and my HHKB at work, but my girlfriend has an Ergo Clear, and I always love the sound of them typing. They feel great too! Kind of like bubble wrap, and not too far from HHKB, but still a very different experience.
Home: Kishsaver - IBM 6019284/F62 | Work: HHKB Professional 2 Silenced | Temporary Retirement:
IBM '89 1391401 Merrill Lynch Financial Edition
They are a functional and practical indulgence.
Offline rf87
« Reply #15 on: Mon, 27 July 2015, 00:03:19 »
You mentioned that you don't prefer heavy switches. In that case, wouldn't you rather consider a Realforce 45g? If you want to try a different flavor of Topre and if you type a lot, then maybe you would like to ponder over buying a Realforce variable type-S.
Realforce 87 UB Variable
Offline trees
  • I like bagels.
« Reply #16 on: Mon, 27 July 2015, 07:21:31 »
I am expanding my budget to closer to 500$ because I have to agree with people that the SSK will be too stiff, and I really want to try something different, so i am looking at a custom board with lubed ergo-clears.
