Author Topic: Mapping arrows  (Read 1812 times)
Offline Alfatastiera
Mapping arrows
« on: Fri, 24 July 2015, 09:35:03 »
I've a problem, I'm undecided to get this keyboard because the arrows keys and the numbers are in the same compacted layout.
So I thought, Is possibile to map like in this image those command keys with arrows with Karabinier?
Re: Mapping arrows
« Reply #1 on: Fri, 24 July 2015, 09:36:39 »
Re: Mapping arrows
« Reply #2 on: Fri, 24 July 2015, 09:38:33 »
Offline trees
  • I like bagels.
Re: Mapping arrows
« Reply #3 on: Fri, 24 July 2015, 09:40:40 »
Code: [Select]
[img]http://s5.postimg.org/7xhorzh3r/Untitled_1.jpg[/img] -- This is the image code you are looking for to make the picture work.
B.Face HHKB - B.mini - Black/Purple Custom
Re: Mapping arrows
« Reply #4 on: Fri, 24 July 2015, 10:29:25 »
thanks...
Offline esoomenona
  • Gnillort?
« Reply #5 on: Fri, 24 July 2015, 10:32:02 »
« Last Edit: Wed, 12 August 2015, 08:07:37 by esoomenona »
Offline esoomenona
  • Gnillort?
« Reply #6 on: Fri, 24 July 2015, 10:33:40 »
« Last Edit: Wed, 12 August 2015, 08:07:47 by esoomenona »
