Author Topic: G8x-1800  (Read 2783 times)
Offline JonasDK
  • Let me poo on you
G8x-1800
« on: Fri, 24 July 2015, 11:56:37 »
Is anyone able to determine if this is a MY or MX board? Seller doesn't bother to take a picture of the backside as he has packed it away, but I can get it for fairly cheap (Around 15 USD shipped). I only want it incase it's a MX board, but if it's MY and someone wants it for the caps or case, I'll happily proxy for free.
« Last Edit: Fri, 24 July 2015, 12:38:26 by JonasDK »
Offline merlin64
    • MechMerlin
Re: G8x-1800
« Reply #1 on: Fri, 24 July 2015, 13:09:02 »
Hard to tell for me too, but in any case, the keycaps look like they are PBT or POM so for $15, why not?
Re: G8x-1800
« Reply #2 on: Fri, 24 July 2015, 13:11:32 »
Would really be helpful if we could see the back. Hard to guess either way. It's probably lasered POM though at that price. Won't be PBT. Doubtful it's doubleshot ABS but like I said it's really hard to tell.
Re: G8x-1800
« Reply #3 on: Fri, 24 July 2015, 14:55:50 »
More likely to be doubleshot ABS if they are black and 1.5 wide. Black 1.5 wide modifiers are not that common. For $15 shipped why have you not bought it already? Do it!
Offline Blackhawk
Re: G8x-1800
« Reply #4 on: Fri, 24 July 2015, 15:02:35 »
Is the seller located in Denmark? If you don't wanna buy it, I might take the chance :)
Offline JonasDK
  • Let me poo on you
Re: G8x-1800
« Reply #5 on: Fri, 24 July 2015, 16:33:59 »
I actually called the seller, he told me he wasn't home and wouldn't be until monday, but would get back to me when he does. If it turns out to be a MY board I'll probably just resell it cheaply.
« Last Edit: Fri, 24 July 2015, 16:37:33 by JonasDK »
Re: G8x-1800
« Reply #6 on: Fri, 24 July 2015, 20:06:10 »
The ^6 key hints that it's doubleshot ABS.  Also, it looks like F+J are scoops, so, I'm guessing doubleshot ABS over POM.
Offline slickmamba
Re: G8x-1800
« Reply #7 on: Fri, 24 July 2015, 20:15:50 »
Oh god, I'll take it for the 1.5 WoB mods haha
Hi :)
Offline njbair
    • nickbair.net
Re: G8x-1800
« Reply #8 on: Fri, 24 July 2015, 21:32:50 »
What about the ^6 key makes you think doubleshot? Just curious.
My boards:
Offline bazh
Re: G8x-1800
« Reply #9 on: Fri, 24 July 2015, 22:25:09 »
I can tell from the legend that it's doubleshot ABS, now it comes down to the price, even if it's a G81, still worth it for the WoB keycaps and the 1.5x mods
HHKB Pro2 white
Newbie again
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: G8x-1800
« Reply #10 on: Sat, 25 July 2015, 11:22:10 »
It's definitely a doubleshots model. I don't see any shiny silver color between keys, so I also will guess its a G80.
