Author Topic: Unicomp Model M: something strange just happened  (Read 1686 times)
Offline macguy80
« on: Fri, 24 July 2015, 21:01:01 »
I was typing along, and suddenly the period/full stop key went completely linear: no click of any kind. Yet the key still registered perfectly.
I hammered on it repeatedly (maybe 100 times or so, and it is suddenly working properly.
Anyone ever had that happen? I'm glad it's back to normal as I don't have a proper keypuller. I really need to get one of the wire-type ones. And I really don't know much about the care and feeding of a bucking spring switch, so opening it probably would have made the situation worse. ;)
I wonder what happened, since typing both caused and corrected the problem? I was close to emailing Unicomp when it fixed itself.
Offline njbair
    • nickbair.net
Re: Unicomp Model M: something strange just happened
« Reply #1 on: Fri, 24 July 2015, 21:23:51 »
Every once in a while, especially when pulling caps, a spring will become improperly seated so that it doesn't buckle. Usually it's enough to pop the cap off and put it back on.
My boards:
Offline BucklingSpring
« Reply #2 on: Sat, 25 July 2015, 13:05:32 »
What he said :-)
Boards I own, click ->
