Author Topic: unicomp 122 terminal software  (Read 1721 times)
Offline williamjoseph
« on: Tue, 06 October 2009, 15:18:31 »
any direction for a driver or some other capable software that can translate for a unicomp 122 terminal 5250 emulator keyboard?  will need xp32x and vista 64x drivers.  the unicomp websight has none posted.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #1 on: Tue, 06 October 2009, 16:19:31 »
Quote from: ripster;123505
Just plug it in.  Weird translations though.  SHF-F1 for F13?
They may not be talking about that keyboard, the PC/5250. Those translations are specifically for IBM's Client Access/400 software. Many terminal programs will work with a Host Connected Keyboard, which is what their "ordinary" 122-key Terminal Emulator keyboard works like.
Offline ironcoder
« Reply #2 on: Wed, 07 October 2009, 14:05:36 »
Quote from: williamjoseph;123494
Is that for native use with your Windows box or tn3270 to an IBM host?
In the office: Filco 87 Cherry Browns x 2 (one with coffee damage, recovered) ● Lexmark IBM Model M 52G9658 1993 & 1996
« Reply #3 on: Wed, 07 October 2009, 17:56:22 »
windows box, my problem was that i was trying to use a USB adapter instead of using the PS2 adapter.  this terminal keyboard will not work through a USB port on a windows machine but will work with a PS2 port.  my bad.......
