Author Topic: Need Some Advice  (Read 1919 times)
Offline Bentekkers
Need Some Advice
« on: Sun, 26 July 2015, 01:50:50 »
Ok, so i just some money to spare for this type of Hobby
My Choice are:
Ducky Legend $140~150
Ducky Shine 4 $160
i just confused on which one i should buy...
at one point i want aluminium body, but the color customization from shine 4 is really interesting...
(i want full keyboard, the one with numlock too)
also should have cherry MX blue switch (or similar to this)
anyone have some alternative? if not which one should i choose? the aluminium or the shiny lightning?
Re: Need Some Advice
« Reply #1 on: Sun, 26 July 2015, 03:19:41 »
Welcome to Geekhack!
The Legend only has an aluminium case top - the rest of the case is plastic.
Fancy lighting modes are usually difficult to retro-fit to a keyboard, so this will probably come down to what is more important - flashy lighting or metal case top.
Either should be fine, although I'd go for the S4ine 4, as there are other keyboards that you can fit into a full aluminium case (granted most are TKL though).
Offline Bentekkers
« Reply #2 on: Sun, 26 July 2015, 03:29:47 »
well shine 4 have its coolness tho, but if only ducky legend have pink colored led i will def buy them
i guess im going for shine 4 then
« Reply #3 on: Sun, 26 July 2015, 03:43:49 »
You might end up getting both anyway ;)
Offline Bentekkers
« Reply #4 on: Sun, 26 July 2015, 10:49:02 »
actually, they actually sell shiny 4 full metal (aluminium case) but only available in clear switch damn now im confused. never tried clear switch (from red, brown, black, and blue i love blue the most) should i go for this, or should i just get a white shine 4?
« Reply #5 on: Mon, 27 July 2015, 06:03:45 »
Clear is tactile like brown (i.e. a little bump as the switch actuates), but stiffer.  If you want something clicky, don't get clears.
