Author Topic: Help determining XT pinout for Teensy conversion  (Read 2683 times)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« on: Sun, 26 July 2015, 17:58:23 »
Hi guys, I am using this cable and am wondering if someone could help me determine how to connect this to my Teensy. The back of the PCB doesn't tell me anything.
Offline VinnyCordeiro
Re: Help determining XT pinout for Teensy conversion
« Reply #1 on: Sun, 26 July 2015, 19:35:19 »
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #2 on: Sun, 26 July 2015, 22:54:15 »
Since I couldn't seem to find any info online, I mangled the cable and managed to pull the wiring and header out of the rubber sleeving intact. I arrived with this:
However, I want to make sure I am understanding this diagram. This is the socket view, correct (i.e. female side of the connection)?
