Author Topic: Key Cap Weight. Do you have a preference? Why?  (Read 6201 times)
Offline Ramage
« on: Sun, 26 July 2015, 21:18:16 »
Do you prefer heavier or lighter key caps? Do heavier ones feel significantly different?
Re: Key Cap Weight. Do you have a preference? Why?
« Reply #1 on: Mon, 27 July 2015, 05:35:43 »
I have never weighed a keycap, however I prefer stiffer switches, and thicker (and consequentially heavier) keycaps seem to go well on such boards.
However for a lighter board (e.g. MX reds or blues) I definitely prefer lighter keycaps, something like SP DCS or even not-too-thick GMK ABS.
« Last Edit: Mon, 27 July 2015, 05:40:02 by rowdy »
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #2 on: Mon, 27 July 2015, 07:34:36 »
I can't tell much of a difference in use but I think that in theory lighter caps should respond quicker.
Offline Oobly
« Reply #3 on: Tue, 28 July 2015, 08:36:30 »
Heavy caps all the way. My SA profile caps weigh around 2g each and I'm loving it. Lighter caps all feel "cheap" to me. It's thick Cherry or SA profile for me.
62g ErgoClears.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Ramage
« Reply #4 on: Tue, 28 July 2015, 13:31:53 »
That's good to know, thanks for the replies.
Offline Hue
« Reply #5 on: Tue, 28 July 2015, 17:28:32 »
Is there a huge difference with weight? I have only owned two keycaps and I don't seem to see a difference :/
« Reply #6 on: Tue, 28 July 2015, 21:36:11 »
Yes.
With weaker springs (MX reds, browns, blues) heavier keycaps (SA) tend to take much less effort to push the keys down, almost collapsing under the weight of your breathing.  Well, slight exaggeration, but you get the point.
SA keycaps are generally very thick, as well as being very tall, hence a lot of plastic, which is quite heavy on a weak-springed switch.
