Author Topic: 2 keyboards on 2 PCs but I can use both on both machines?  (Read 2279 times)
Offline neverlast74
« on: Tue, 28 July 2015, 01:25:46 »
I have 2 PCs and 2 keyboards - what is needed if I want to use both on both machines - not at the same time but ... is there a "switch" What is it called? Unplugging is not an option. :-*
Thanks....
Tour de kübord - Germany Layout:
Original IBM model M (too loud) -> rubber dome IBM Rapid Access II (mediocre) -> Cherry STREAM XT scissor switch (somewhat OK) -> G80 with clear (too hard for me) -> Zowie Celeritas with brown (good but dirty)-> Filco Majestouch 2 Brown (great) -> CM NovaTouch + Filco Doubleshots (best)
Offline NiV
Re: 2 keyboards on 2 PCs but I can use both on both machines?
« Reply #1 on: Tue, 28 July 2015, 01:57:58 »
Hey
What about something like this: http://www.amazon.com/Sabrent-4-Port-Individual-Switches-HB-UMLS/dp/B00BWF5U0M/ref=pd_sim_147_2?ie=UTF8&refRID=16ENRYPPM5SBDC1BFCE2 + one of these http://www.startech.com/ch/en/Cards-Adapters/USB-2/Hub/4-to-1-USB-Peripheral-Sharing-Switch~USB421HS?
With this setup you'd have to be fancy :P You would need to connect your KBs into the first one and connect this switch into the second adapter, which is connected to both pcs. Never tried something like that but I'm sure that would work!
« Reply #2 on: Tue, 28 July 2015, 02:04:10 »
One of these?
I wanted one years ago but couldn't find one, today I found it no problem and it seems such device have been around since 2007 :-\
Offline OverKill
« Reply #3 on: Tue, 28 July 2015, 05:30:08 »
What you are  looking for is called a KVM switch. Newegg carries  them as well as pretty much anywhere.
Offline SeeThruHead
 Painted QFR          Poker 2
« Reply #5 on: Tue, 28 July 2015, 13:09:45 »
You need to be careful if they create virtual devices though - I tried a couple but they were designed for a keyboard and a mouse so my USB stick wasn't recognised, but the computer did see an invisible mouse!  Plus both keyboards would be connected to the same computer at the same time which doesn't sound too helpful (but maybe that is what the OP wants :) )
Offline cutterline
« Reply #6 on: Wed, 29 July 2015, 02:01:49 »
Filco Majestouch 2 Convertible might be the answer.
The downside both PC needs to have Bluetooth.
