Author Topic: [GB] TGR-Jane custom TKL keyboard (COMPLETED)  (Read 284135 times)
Offline Danboard
Re: [GB] TGR-Jane custom TKL keyboard Update 28/10/2015
« Reply #600 on: Fri, 05 February 2016, 22:47:57 »
Still can't seem to fix the ping... Tried foam and rubber.
All keys ping or just some?
Everything
What plate? I have a ss plate, never had any pinging issues, although you can feel that there are some extra air under the pcb.
Aluminum
Have you tried taking the plate and PCB out of your housing and making sure that all the switches are completely 'locked' onto the plate? Some of the switches might be somewhat lifted off the plate itself, bending the plate, that is what caused my keyboard to make the pinging sounds when I first assembled it.
I have an aluminum plate also.
Edit: if it is your stabilizers that are causing the pinging sound, then you should check out my advice to Romevi. If it's a regular key that's causing it then this is the only thing I can think of.. I hope that helps man
Nope, no keys that I can see not properly seated. And it's not just stab keys, it's every key. Oh well, it's not horrible at least and I pretty much always have music on anyway
I had ping like that on one of my other boards. What I did was put drawer liner under the PCB, but instead of just a normal amount I added enough to make it flex the PCB ever so slightly upward. This upward pressure eliminated the ping for me.
« Reply #601 on: Tue, 16 February 2016, 22:42:38 »
All right, so I finally got around to taking apart my board and adding some lube. It definitely helped a lot, but there's still ping and a little rattle. Since I couldn't remove the plate I had to carefully add some thick lube where I could reach. It eliminated almost all the rebound rattle, so that all that's left is the initial rattle and ping. It most certainly feels smoother, however.
Offline eten
« Reply #602 on: Mon, 01 August 2016, 16:10:42 »
Yuktsi,
I have tried messaging you via PM 3 times without any responses before I decided to post on this thread. I have paid all my fees 3 months ago (delay on my part for the shipping fees, but paid in May) and still have not received my keyboard or any updates. This is for the original TGR-Jane.
Could you please let me know if there is anything outstanding to get my order moving?
Offline Bevo
« Reply #603 on: Mon, 01 August 2016, 23:12:01 »
Also looking for an update on my CE. Thanks Yuktsi
« Reply #604 on: Mon, 01 August 2016, 23:23:26 »
While this has been bumped, is there a list of PCBs that work with this? I think the Nerd TKL works. Any others?
Offline henz
  • What?
« Reply #605 on: Tue, 02 August 2016, 00:41:10 »
Dont forget that gons space bar stab is flipped, so if you want to use that some plate modifications might be needed.
All a87 compatible pcbs work.  So all the ps2avr etc
« Reply #606 on: Tue, 02 August 2016, 09:18:21 »
Hmm, okay. I was hoping to get a PCB that had better RGB customization and was able to brighten/dim the in-switch LEDs.
What sort of plate modification is needed? Will the modification make the TX87 unusable if, for some odd reason, I decide to switch back in the future?
Offline henz
  • What?
« Reply #607 on: Tue, 02 August 2016, 09:22:15 »
It wont affect the use of the tx87 pcb, here is a link on what needs to be done, ive done it to two boards
http://www.gonskeyboardworks.com/manuals/138-modding-kmac-plate-for-nerd-tkl.html
« Reply #608 on: Tue, 02 August 2016, 09:29:03 »
Oh, neat. Thanks!
Offline eten
« Reply #609 on: Thu, 04 August 2016, 09:13:47 »
Yuktsi,
I still have not received any updates or replies to my PM for those who have messaged me asking for status.
Offline eten
« Reply #610 on: Fri, 05 August 2016, 09:01:43 »
Update:
Yuktsi replied to my PM stating shipping will occur next week. Thank you everyone!
Offline kconfire
« Reply #611 on: Wed, 25 January 2017, 11:28:26 »
Anyone selling their 86/86 full plated TGR Jane?
Preferably Titanium Gray color ones... anybody?! :D
[Collection] Monokei Kei SE, Realforce R2 TKL, Leopold FC660C
[Soon TM] Monokei Tomo SE, GSKT-00
« Reply #613 on: Wed, 25 January 2017, 12:45:30 »
Dat necro!
Sounds like my kind of poster.
Offline kconfire
« Reply #614 on: Wed, 25 January 2017, 13:00:54 »
SOMEBODY SELL ME THE 86/87 TITANIUM GRAY TGR JANE w/ FULL PLATE PLEASE! lol
My wallet is ready..
Offline kconfire
« Reply #615 on: Wed, 25 January 2017, 13:02:36 »
Dat necro!
Dat necro!
removi do you still have your #7?
If you ever sell yours... I'll be there :(
Offline Kominyetska
« Reply #616 on: Wed, 25 January 2017, 13:03:18 »
Ummm... https://www.reddit.com/r/mechmarket/comments/5q5176/ussdh_tgr_jane_steel_plate_vintage_blacks_w/
Offline kconfire
« Reply #617 on: Wed, 25 January 2017, 13:06:05 »
I've spoken with chilldude_22 and he spent quite some time answering my question and everything about his keyboard sounds good to me, except that he said he doesn't have the original brass engraved #15 weight on the keyboard.
Sure, you could say it's not much but to me that means quite a bit if I were to pay a hefty premium for the keyboard.
If I can somehow get the original #15 engraved weight back.. I will most likely pull the trigger.
« Reply #618 on: Wed, 25 January 2017, 13:10:48 »
Dat necro!
Dat necro!
I'll let you know, but I don't think I'm ever going to part with mine. Already got two more TGR boards on the way.  ;D
Offline kconfire
« Reply #619 on: Wed, 25 January 2017, 13:13:22 »
Dat necro!
Dat necro!
Ah, okay..well- I tried!
Which TGR boards did you order? Wow you're having 3? lol
Let me guess, are they TGR Jane CEs?
Good for you! :D
« Reply #620 on: Wed, 25 January 2017, 13:14:01 »
Dat necro!
Dat necro!
Good for you! :D
Jane r1, 910, and Tris.
Offline kconfire
« Reply #621 on: Wed, 25 January 2017, 13:18:57 »
Dat necro!
Dat necro!
Good for you! :D
That's awesome but hey, just please remember me when you wanna sell your TGR Jane for me +_+!
I see you're quite a fan of TGR keyboards.
Only keyboard and the first custom keyboard I jumped on GB for in my life is Rama's M65-A and I am excited.
If I can get my hands on TGR Jane 86/87 w/ full plate in Titanimum Gray my life will be complete, until the amazing Duck Lightsaver v3 comes out shortly ;)
I'm planning to get at least 2 or if there's no limit 3 Duck Lightsaver v3 and make my own trinity hehe
« Reply #622 on: Wed, 25 January 2017, 13:23:47 »
Dat necro!
Dat necro!
Good for you! :D
The Jane r1 was my first custom keyboard. I love it! (Just not the PCB.)
« Reply #623 on: Wed, 01 February 2017, 11:09:30 »
Super random, but I don't suppose anyone would be willing to swap the top casings of the Titanium Gray with me? I have the Winkey top. Looking for Winkeyless now.  :-[
Offline Unforgivable
Re: [GB] TGR-Jane custom TKL keyboard (COMPLETED)
« Reply #624 on: Wed, 01 March 2017, 21:19:49 »
If anyone is interested in selling their TGR Jane (FMJ Style) please let me know! I love the look of the case. (:
Offline HTN47
  • Mr. SoCal
« Reply #625 on: Wed, 26 April 2017, 21:32:37 »
Anyone know how I can purchase an additional TX87 PCB? I've looked into purchasing a GONs PCB but his website seems to be messed up during payment process.
Thank in advance!  :thumb:
What is love.... Baby don't hurt me... No more!!
Offline fublamchu
  • ㅋㅋㅋ
« Reply #626 on: Wed, 26 April 2017, 21:33:56 »
You may be able to get one from Kin if you PM him
LZ-CE VBlacks
910-CE
Offline HTN47
  • Mr. SoCal
« Reply #627 on: Wed, 26 April 2017, 21:40:57 »
Would you happen to know his exact user name on GH? I can't seem to find him.  :(
Offline mrboovn
« Reply #628 on: Wed, 26 April 2017, 22:03:53 »
https://geekhack.org/index.php?action=profile;u=12327
Offline HTN47
  • Mr. SoCal
« Reply #629 on: Thu, 27 April 2017, 00:20:16 »
Thank you good sir!  :)
Offline beamingrobot
  • もうけい
    • monokei
« Reply #630 on: Thu, 27 April 2017, 00:57:48 »
I got mine from Kin, quick and easy process  :thumb:
http://monokei.co
Jane v2 | Jane v2 CE | Police | EXENT | KFE | KFE CE | Singa R1 | Jaguar | HHKB | Custom G80-3000 | Dalco 959mini | Haus | Kei | Hiro | Hidari | Tomo | Neko | Prophet | MXSS | TKL One | RS
Offline Mcnos
    • GMK Fuyu
« Reply #631 on: Wed, 11 July 2018, 13:30:39 »
Anyone wanting to sell an extra PCB?
« Reply #632 on: Wed, 11 July 2018, 14:14:30 »
Anyone wanting to sell an extra titanium gray WKL top?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #633 on: Wed, 11 July 2018, 15:59:46 »
Anyone wanting to sell Jane v2?
« Reply #634 on: Tue, 11 December 2018, 13:31:05 »
Anyone ever have the RGB go haywire? It's happened to me a few times over the years, but recently it's stuck like that. It'll flicker constantly. I've tried updating the firmware, resetting the RGB settings, and disconnecting it. Nada. Going on day four with no fix. A few times it's fixed itself, but not more than a day after it'll start doing it.
(yuktsi notice me senpai)
« Reply #635 on: Tue, 11 December 2018, 14:40:57 »
Are you using a TGR PCB or an L3 PCB? This is a known issue on L3 pcbs that usually can be fixed with a firmware update. If that doesn't do it, it's more than likely a faulty voltage regulator chip.
« Reply #636 on: Tue, 11 December 2018, 14:46:49 »
L3 PCB. It's happened more than a handful of times so I'm no stranger to it, but this is the longest it's gone without a fix. This is where I've always gotten the latest firmware:
http://kbdlab.co.kr/index.php?document_srl=2702787&mid=board_sw
L3_171209.zip is the firmware I've uploaded, but it was the last one I've used so there's nothing new.
« Reply #637 on: Tue, 11 December 2018, 14:58:25 »
Yeah, I've got the same one. Might want to look into a rebuild.
« Reply #638 on: Tue, 11 December 2018, 15:52:33 »
UGH.
Offline futurecrime
  • Get Zooted
« Reply #639 on: Tue, 11 December 2018, 16:48:45 »
UGH.
Get a Hiney PCB innit.
« Reply #640 on: Tue, 11 December 2018, 17:37:12 »
UGH.
Link? Will it fit Jane?
I keep forgetting what PCBs and plates work with this board. Anyone care to give a short list for lazy, ol' me?  :rolleyes:
Offline futurecrime
  • Get Zooted
« Reply #641 on: Tue, 11 December 2018, 19:02:04 »
UGH.
H87a will fit Jane. https://geekhack.org/index.php?topic=97316.msg2658067#msg2658067
He's posting them out at the moment. He might have extras or someone will probably decide they don't want theirs anymore and sell it to you. Or you could wait til next round. Or you could see if someone has a spare Mech27 PCB, they fit as well.
Offline Malicium
« Reply #642 on: Tue, 05 May 2020, 08:38:57 »
Finally done it after five years :)
Offline thotran7989
« Reply #643 on: Sat, 10 June 2023, 02:28:40 »
10/20
