Author Topic: Does any existing PCB support this custom layout?  (Read 1836 times)
Offline BigTinz
« on: Tue, 28 July 2015, 12:12:55 »
Best name I could think of is modified Colemak.
Offline azhdar
  • Praise the AZERTY god
Re: Does any existing PCB support this custom layout?
« Reply #1 on: Tue, 28 July 2015, 12:17:59 »
Azerty Propagandiste
Offline VinnyCordeiro
« Reply #2 on: Tue, 28 July 2015, 12:42:43 »
Have a look there :
https://geekhack.org/index.php?topic=72329.0
We are only waiting to assemble the prototype to start the group buy, which will firstly be the right-sided numpad version. The left-sided numpad version PCB is already designed, though, and I made it in a way that both versions are firmware-compatible. Code once, flash many!  :))
