Author Topic: Another TMK-Powered Keypad Lobotomy - Genovation UPS Controlpad  (Read 8003 times)
Offline IBNobody
Here's what I have to work with...
http://imgur.com/a/uIj9b
I think that the unit was originally intended as a wall-mount timecard entry system or something.
I'm pretty excited because the actual keypad has everything I wished my last project (Goldtouch lobotomy) had. This keypad has 35 plate-mounted Cherry MX black switches, red LEDs, and per-key backlighting thanks to a set of I2C I/O extenders.
I plan on removing the bottom MCU board and replacing it with a Teensy 2.0++ and TMK.
In case anyone finds another one of these, here's what I've done to reverse engineer it.
The I2C extenders need to be mapped, still, but they have sequential I2C addresses (0b000 to 0b100).
Keypad-to-MCU Cable Pinout:
01 - VCC (+5V)
02 - VCC (+5V)
03 - SCL (U8p14)
04 - SDA (U8p15)
05 - Col #1 (U8p21)
06 - Col #2 (U8p22)
07 - Col #3 (U8p23)
08 - Col #4 (U8p24)
09 - Col #5 (U8p25)
10 - Row #1 (U8p39)
11 - Row #2 (U8p38)
12 - Row #3 (U8p37)
13 - Row #4 (U8p36)
14 - Row #5 (U8p35)
15 - Row #6 (U8p34)
16 - Row #7 (U8p33)
17 - Row #8 (U8p32) * Keypad does not have Row #8, but MCU supports it
18 - GND
19 - GND
20 - Shield
RJ-45 Pinout:
01 - RS-422 A
02 - RS-422 B
03 - VCC (+5V)
04 - VCC (+5V)
05 - VCC (+5V)
06 - GND
07 - GND
08 - GND
Offline grantb3
Re: Another TMK-Powered Keypad Lobotomy - Genovation UPS Controlpad
« Reply #1 on: Mon, 03 August 2015, 09:40:02 »
Hey good job. Keep us posted. I've seen these on eBay a few times.
Offline rich1051414
« Reply #2 on: Sat, 30 September 2017, 21:40:19 »
Any progress? I came across this at the recycling center, and I can't find much about this except this post. I also plan to get this functioning as a programmable pad.
Also, you didn't seem to talk about the dip switches. Any idea what they do?
PS: Look at those double shot DSA windowed caps!
« Last Edit: Sat, 30 September 2017, 21:52:41 by rich1051414 »
Offline lishi
  • Luxury Taste Buds
    • Personal Website
« Reply #3 on: Fri, 13 October 2017, 14:10:56 »
There's a genovation pcb in the OTD Pad, so that might help you out
All the kustom 60s
