Author Topic: Anyone else getting this annoying taskbar issue in Windows 8.1?  (Read 1636 times)
Offline Coreda
Since about a week ago various pinned apps on the taskbar no longer minimize/restore when their taskbar hotkeys are pressed (Win+1-9), instead the windows focus/unfocus. It's a super handy hotkey so the sudden breaking of the feature is really rustling my jimmies.
If anyone is using an up to date Windows 8.1 could you try pinning Wordpad (or File Explorer) to the taskbar in the first position closest to the Start menu then press Win+1 a few times. Does it minimize/restore or merely focus/unfocus the window?
Offline heedpantsnow
  • Old enough to know better
Re: Anyone else getting this annoying taskbar issue in Windows 8.1?
« Reply #1 on: Thu, 30 July 2015, 14:23:01 »
This happens to me sometimes if my explorer.exe has crashed. I open task manager and restart windows explorer. Happens only about once a week and only on one of my W8.1 machines.
I'm back.
Offline paicrai
  • mindblank
« Reply #2 on: Thu, 30 July 2015, 15:39:06 »
i know the only time i "upgraded" to w8.1 (and spent 3 days afterwards backdating to 8 without an 8.1 key to grant me admin abilities) it took literally 8-10 minutes to just launch, the taskbar was partially blacked out, start menu thing was broken, explorer and other system functions just... didnt work (most things didnt) and i couldnt seem to do anything about it
THE FEMINIST ILLUMINATI
  • Live long and prosper
« Reply #3 on: Thu, 30 July 2015, 16:11:01 »
i get this weird taskbar issue in Server 2012 where it will show items in the taskbar like Windows Explorer or Control Panel, but then when you click on them, they say that they don't exist and asks me if i want to remove them from the taskbar
and then 5 minutes later, they work again
i blame folder redirection...
tp thread is tp thread
Offline Coreda
« Reply #4 on: Fri, 31 July 2015, 08:54:36 »
I'm thinking it's a recent Windows update for me, as I tried that but no difference. Affects other apps, too. Exited all background programs I could think of that may be conflicting but the problem persists.
It's my most used taskbar feature :( May try submitting a bug report to Microsoft if I can find a link.
