Author Topic: NerD 60 custom wood case  (Read 3821 times)
Offline yobinad
« on: Thu, 30 July 2015, 08:02:04 »
Update
Case
Lub station :))
3D printed angle "feet"
Armstrong foam adhesive tape guarantees solid standig
Used some double sided adhesive tape to glue the feet to the case
« Last Edit: Thu, 20 August 2015, 16:26:10 by yobinad »
Offline cwils0n
  • twiggletwaggle
Re: NerD 60 mini build log
« Reply #1 on: Thu, 30 July 2015, 08:11:54 »
Very well done my friend.  I really dig the milled wood case, did you make it yourself?
Offline yobinad
« Reply #2 on: Thu, 30 July 2015, 08:18:09 »
Thank you  :thumb:
A friend made it on his cnc machine. He also printed the "feet".
Offline cwils0n
  • twiggletwaggle
« Reply #3 on: Thu, 30 July 2015, 08:36:36 »
I'd imagine quite a few people would love a case (and feet) like that.  Again, great work!
Offline petrock
« Reply #4 on: Tue, 04 August 2015, 08:32:41 »
I would love some more info on the case you made.
Offline Thumper_
  • Spend all my money.
« Reply #5 on: Wed, 05 August 2015, 03:16:42 »
Which key caps are that?
Offline yobinad
« Reply #6 on: Wed, 05 August 2015, 03:18:14 »
What would you like to know?
Those are cherry laser etched
Now has Tai Hao orange set
« Last Edit: Wed, 05 August 2015, 03:22:01 by yobinad »
Offline yobinad
« Reply #7 on: Thu, 06 August 2015, 17:14:36 »
These are the two 2D files used to make the case.
Mind that this was made for ISO. ANSI requires some dremel on pcb support because LEFT SHIFT and ENTER stabs, and because of  some in-switch leds on the bottom row.
The desirable depth was defined between gcode lines.
Inside and outside
Offline yobinad
« Reply #8 on: Wed, 12 August 2015, 18:11:04 »
Milled the pcb support 1mm and 3 on the bottom of the case.
Made a short video with me working with a "state of the art machine", milling the bottom of the case.
Offline yobinad
Re: NerD 60 custom wood case
« Reply #9 on: Thu, 20 August 2015, 15:15:34 »
Made some changes in the case.
The switches were 4mm higher than i want. Milled 1mm of pcb support and 3mm at the bottom of the case.
I treated the case with oak stain, two coats.
Glued 1mm rubber to the letters with double sided adhesive tape and glued the letters to the case with double sided adhesive tape as well.
Now i'm waiting for the gateron browns and for the HONEYB/CREAM set to finish it.
