Author Topic: Hello & thanks  (Read 2782 times)
Offline Jarlax
Hello & thanks
« on: Sat, 01 August 2015, 11:16:31 »
Hi guys. ~ year ago I've decided to buy mechanical keyboard (and switch layout from Qwerty to Colemak, but that's a different story).
Here I found a lot of useful information which helped me to decide what to choose, so thanks everyone!
P.S. I'm happy owner of WASD V2 10keyless (MX Clears) and HHKB Pro 2 Type S.
Cheers,
J
Re: Hello & thanks
« Reply #1 on: Sun, 02 August 2015, 02:16:35 »
Welcome to Geekhack!
Two excellent keyboards you have started with :)
Have you got a preference for either one?  Or a specific use you put one to?
Offline Jarlax
Re: Hello & thanks
« Reply #2 on: Sun, 02 August 2015, 06:59:31 »
WASD was the first one and I enjoyed it a lot. But it's a little too big and heavy for every day transportation from home to work and back. So, I've decided to buy 60% keyboard. Now I use mainly HHKB. Main reason is size - 60% works much better for me than 80%. Also, although I still like Clears, Topre feels more satisfying.
Usage: 80% work (coding, emails etc), 20% gaming.
Re: Hello & thanks
« Reply #3 on: Mon, 03 August 2015, 05:02:57 »
The HHKB is a bit lighter than many 60% boards, so you've chosen well there :)
Do you miss dedicated arrow keys and home/end when coding with the HHKB?  I find I use those keys too much when coding, and that's pretty much what stops me from using my HHKB at work.  Instead I use it at home where Ctrl sequences to a lot of the navigation instead.
Offline Jarlax
Re: Hello & thanks
« Reply #4 on: Sun, 30 August 2015, 08:43:16 »
For me Fn+;['/ feels more comfortable comparing to dedicated arrow keys (even with combinations like Ctrl-Shift-Left). The only real problem was with F1-F12 with modifier keys (lots of hotkeys in Visual Studio are like that).
Offline raymogi
Re: Hello & thanks
« Reply #5 on: Sun, 30 August 2015, 08:54:51 »
Great choice in keyboard there ;)
Just got my type-S today too and oh my, I'm feeling the Topre love all over again. When I chose to buy the normal one, I had gone through youtube videos and decided that I like the clackiness of the normal model. But after using it in person, the type-S is just a different kind of sexy.
Please feed my addiction.
Offline zars15
Re: Hello & thanks
« Reply #6 on: Sun, 30 August 2015, 10:43:27 »
(..)Do you miss dedicated arrow keys and home/end when coding with the HHKB?  I find I use those keys too much when coding, and that's pretty much what stops me from using my HHKB at work.  Instead I use it at home where Ctrl sequences to a lot of the navigation instead.
What about vim-like editors? After I switched to it, I can't live without it. Though it only works if you go with homerow style.
Re: Hello & thanks
« Reply #7 on: Mon, 31 August 2015, 05:26:13 »
I got that when I tried to use my HHKB at work - the IDEs we use need far too many function keys to work, with especially without the gap better f1-f4, f5-f8 and f9-f12 I found myself looking down at the keyboard far too much.
Much, much easier :)  Also on the Mac (and other Unix-like operating systems) you can use control sequences instead of separate cursor movement keys, so Ctrl-A moves cursor to beginning of line, Ctrl-F moved forward one character, Ctrl-D deletes the current character and so on.  With the HHKB's Control key position this makes navigation easy and intuitive :)
Re: Hello & thanks
« Reply #8 on: Wed, 02 September 2015, 22:36:16 »
hi and you're welcome
