Author Topic: [Solved] Pressing caps on phantom triggers entire row  (Read 2139 times)
Offline Jersern
  • Australian Keyboard Modding and Repair Service
« on: Sun, 02 August 2015, 03:37:52 »
As the title says. All other keys work fine. The caps lock on the other hand.......... :(
Any advice is welcome!
Solved... for now.......
« Last Edit: Sun, 02 August 2015, 03:51:17 by Jersern »
Re: [Help] Pressing caps on phantom triggers entire row
« Reply #1 on: Sun, 02 August 2015, 03:41:25 »
Is the diode backwards?  Sounds likely :)
Offline Jersern
« Reply #2 on: Sun, 02 August 2015, 03:44:33 »
I don't think so since it was working before I pulled it apart to clip stabs but I'll defs take a look. Thanks :)
Offline Jersern
« Reply #3 on: Sun, 02 August 2015, 03:50:22 »
Well since it wasn't the diode and I could observe nothing wrong, I took desoldered the switch and gave it a reseat and seems to work now. :D
