Author Topic: [eBay] Huge Variety of Custom & Replacment Happy Hacking Keyboard Keys  (Read 7598 times)
Offline Cicada88
Shipping mainly available to some countries outside of USA but message me beforehand.
Combined shipping available.
http://www.ebay.com/sch/compint_tko/m.html?_nkw=&_armrs=1&_ipg=&_from=
Offline PocketFool
  • Coming down with a serious case of mech-mania
Re: [eBay] Huge Variety of Custom & Replacment Happy Hacking Keyboard Keys
« Reply #1 on: Sun, 02 August 2015, 16:24:48 »
The grey keys have been up for quite some time - and have included a pretty comprehensive collection of different modifier keys from the HHKB - but this is the first that I've seen some of these colorways, which are (in my opinion) odd colorways. Do you know any more info on the keys themselves? I know that they're dyed, and are PBT keys, so I'm assuming they're dyed keys from authentic blank HHKB/PFU keysets, but I'd like to try and get a better idea of the defect probability/quality of the keys themselves.
Always looking for lime-green and red colored topre RF sets.
Offline Cicada88
« Reply #2 on: Sun, 02 August 2015, 16:47:26 »
Thanks for checking out the keys.
All keys are either factory PFU / Topre keys or dyed from factory PFU / Topre keys.
They are all extremely uniform with one caveat.  The modifier keys of the same color are slightly darker due to them starting as grey instead of white.
As far as quality control, I would guarantee their quality.  I hand inspect every key after they have been dyed and so far have only found 2 that had any issues.
Offline PocketFool
« Reply #3 on: Sun, 02 August 2015, 17:07:26 »
That actually explains why the colorways seemed close to factory red/pink/etc. but seemed off in some way. I actually love the maroon (and think it'd go incredibly well with Martin's HKP topre blanks he just had a sale for), but I'll be holding out in hopes for some green keys. Great product though!
Offline Cicada88
« Reply #4 on: Sun, 02 August 2015, 17:17:58 »
Thanks Project.
Do you have any particular green in mind?  I plan to try some other colors soon if I can get ahold of more keys at a decent price.
Offline TastaturenAuslese
  • Formerly temence
  • life marrow suckerer
« Reply #5 on: Mon, 03 August 2015, 03:09:10 »
Love the bordeaux. Do you have any of Esc row keys in Bordeaux? Would buy :D
Home: Kishsaver - IBM 6019284/F62 | Work: HHKB Professional 2 Silenced | Temporary Retirement:
IBM '89 1391401 Merrill Lynch Financial Edition
They are a functional and practical indulgence.
Offline Cicada88
« Reply #6 on: Mon, 03 August 2015, 11:27:12 »
Yes, there is a bordeaux escape key listed!
http://www.ebay.com/itm/151766218284?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
I only made 2 of those actually compared to 5+ of the other colors because I had no more keys left!
« Last Edit: Mon, 03 August 2015, 11:42:52 by Cicada88 »
Offline PocketFool
« Reply #7 on: Mon, 03 August 2015, 17:40:31 »
I was thinking something along the lines of the lime green Topre keys EK has http://www.elitekeyboards.com/products.php?sub=access,toprekeys&pid=tmod_grn, but I'm unable to find a specific color code used to make them. I'd done some digging around GH to look for color codes/keycaps that I thought looked similar, but the ones that I thought would be closest (Toxic keycap set) and found this post (https://geekhack.org/index.php?topic=37270.150).
After double checking the colors, some seemed a bit off, but I think that coated Pantone 368-C (http://rgb.to/pantone/coated/368-c) or uncoated Pantone 375-U (http://rgb.to/pantone/uncoated/375-u) would be the closest. Just about every one of the light green colors would probably require that white keycaps are dyed though, since I'd imagine it'd be nearly impossible to create them with a grey base color. I could very well be wrong though, but those are just my thoughts/feelings on the topic.
Offline ssdt
« Reply #8 on: Wed, 26 August 2015, 18:38:05 »
Is there any progress with this? Lime green arrow keys/fn keys or powder blue would be so awesome...
Poker II         HHKB Pro 2
“We are what we repeatedly do. Excellence, therefore, is not an act, but a habit.” - Aristotle
