Author Topic: New DSA Dolch on my CM Storm - squeaky backspace fix?  (Read 2064 times)
Offline notbrain
« on: Tue, 04 August 2015, 11:03:54 »
What can I do to get rid of a nasty squeak that's being put out by the backspace key? Most others are fine, but this is the first time I've experienced a real annoying squeak from a multi-stem key like this. Is there some kind of lube that's recommended? Thanks!
Offline Remenition
  • Cooler than your average kid ;)
Re: New DSA Dolch on my CM Storm - squeaky backspace fix?
« Reply #1 on: Tue, 04 August 2015, 20:37:53 »
Saw a post like this on reddit a while back, I could be wrong but I'm pretty sure that relubing it fixed it. Don't quote me on it, but doesn't hurt to try  :D
Offline KHAANNN
« Reply #2 on: Thu, 06 August 2015, 09:50:27 »
Is that a Costar or a Cherry stabiliser?
If nothing is rubbing anything, lubing everything seems like a good idea as a first step
I noticed that DSA keys were actually rubbing the keyboard's sides of my KBParadise V60, my solution was to keep on using the default caps until I move on to another keyboard
