Author Topic: Key often doesn't register or repeats  (Read 2191 times)
Offline bcredbottle
« on: Tue, 04 August 2015, 14:04:53 »
I just built an Ergodox and often the "L" key will either not register at all, or will register 2-3 times even though I only tapped it once. Does anyone have an idea about possible causes?
Re: Key often doesn't register or repeats
« Reply #1 on: Tue, 04 August 2015, 14:06:15 »
First thing to try is to reflow that one switch. Maybe post some good pictures of that area on the PCB.
« Reply #2 on: Tue, 04 August 2015, 14:06:28 »
Could be a bad switch. Could be a bad solder joint.
Get a multimeter and test the joint. If the joint is good, try swapping the switch.
Offline bcredbottle
« Reply #3 on: Tue, 04 August 2015, 14:12:01 »
Reflow? Does that mean just re-solder?
« Reply #4 on: Tue, 04 August 2015, 14:13:23 »
Yes
Offline bcredbottle
« Reply #5 on: Tue, 04 August 2015, 14:40:13 »
I turned over the board and I think I found a clue. While I can't be sure, I believe this is a possible cause of the issue:
It seems that I forgot to solder that joint.
 :llama:
Guess I missed that!
Thank you guys for your expertise.
« Last Edit: Tue, 04 August 2015, 14:42:49 by bcredbottle »
