Author Topic: Reviving an old Datacomp numpad  (Read 2169 times)
Offline 3K
« on: Tue, 04 August 2015, 14:18:29 »
So recently I got me this old numpad. When trying to get it to work I noticed that it needs a driver to allow it to do whatever fancy things it's able to do.
I downloaded the driver, but appearantly the drivers last known compatible Windows version was Windows 2000.
I guess this is the point where I either mod it or sell it. What could I make out of this guy? I thought about a switch tester that displays the switches name in its display. Or simply swap the PCB for a new one?
Any thoughts?
« Last Edit: Tue, 04 August 2015, 14:20:20 by 3K »
Offline 0100010
  • Not Sure
Re: Reviving an old Datacomp numpad
« Reply #1 on: Tue, 04 August 2015, 14:39:57 »
Try using the win2K driver in compatibility mode in the newer OS?
Offline 3K
« Reply #2 on: Tue, 04 August 2015, 15:16:31 »
The problem is there is no executable that I could run in compatibility mode. The downloadable folder only includes system files that are not recognized by my system when chosen as driver.
Offline 0100010
  • Not Sure
« Reply #3 on: Wed, 05 August 2015, 10:22:43 »
Any details in the sys or ini file as to what kind of chip is in the numpad?  Or looked at the chips in it directly?
Offline 0100010
  • Not Sure
« Reply #4 on: Wed, 05 August 2015, 10:31:52 »
After some digging, it looks like that numpad uses an FTDI FT8U232AM chip (RS232 UART to USB).  If that is the case, then a current driver from FTDI from this page - http://www.ftdichip.com/Drivers/D2XX.htm may work.
Offline 3K
« Reply #5 on: Wed, 05 August 2015, 13:39:07 »
Thank you for taking time to help me!
I tried it again with the driver from the site you linked, but it didn't helped.
By now I took it apart - was a btch to desolder, to put it nicely. Cheap solder I suppose...
Reading stuff now to hook up the display to a teensy.
