Poll
Which of these sets would you be interested in seeing made?
SNES
Jazz Solo Cup
Author Topic: [GB] GMK SNES - Hype slowly rekindling...  (Read 433771 times)
Offline sek1ne
  • Sek-eye-n
Re: [IC] GMK SNES - mockups posted - GB to start by month's end
« Reply #200 on: Thu, 19 November 2015, 18:23:04 »
This is a great looking set. I really like the RGBY kesy!
Biking is fun.
Offline Latin00032
« Reply #201 on: Thu, 19 November 2015, 18:23:47 »
This might be too late to ask but the r4 1u keys that are blank, can they have a yellow windows icon or an option for one?
Im asking becuase if you put a 7u spacebar with the shift keys, and 1.5 ctrl/alt mods it will look off without yellow to balance it out.
this is a good point. I think the reason it is this way, is because last time GMK said they couldn't do doubleshot windows logos on 1u keys, and that it would have to be pad printed, so I went with blank. However, those were R5. They might be able to do it for R4. I'll check, and if they can, then I fully support this change.
I'll also love you so much if they can do r4 1units in yellow windows. ;)
SNES was/is the best system ever.
Now I need to mod a pc into an snes shell and hook the keyboard up through a modded controller port adapter.
Offline swimmingbird
  • keyset hoarder
« Reply #202 on: Thu, 19 November 2015, 18:55:13 »
I know that you don't want to blow the set up to an extraordinary size but if child deals are possible do you think the non standard layouts could at least be run separately to see if they can hit MOQ?
By the way any idea on what the MOQ/Pricing is?
Offline Happylomo
« Reply #203 on: Thu, 19 November 2015, 18:58:07 »
Great job, intelli! any chance to put a stepped ctrl key there?  ;D
Offline rpeterclark
  • RPTR ❌
« Reply #204 on: Thu, 19 November 2015, 19:05:36 »
I like how TA was just one set, no child deals, no split MOQ issues. Simple, buy or don't. I do like the dark mod set you have though too though. So yeah, add that to the pile of opinions.
Offline intelli78
« Reply #205 on: Thu, 19 November 2015, 19:12:21 »
I liked it a lot too.
I don't particularly like the dark mod set but there were a lot of people who wanted it, so I decided to be more open minded than in the TA buy and give it a shot.
Not keen to add further child kits -- there is basically zero chance of any of them making MOQ, which will be at least 500.
Offline olijuice
« Reply #206 on: Thu, 19 November 2015, 19:29:24 »
I've noticed that price usually becomes a topic in the comments section of MD. Having a lot of child deals would probably increase that and turn a lot of people off.
  • keyset hoarder
« Reply #207 on: Thu, 19 November 2015, 19:32:39 »
If MOQ is 500 seems fair enough not to include them
Offline jonathanyu
« Reply #208 on: Thu, 19 November 2015, 19:34:26 »
are the light purple custom color? it looks awesome
Offline cooldiscretion
  • Convicted guilty of being totally rad.
« Reply #209 on: Thu, 19 November 2015, 20:36:14 »
Its a shame I see these really nice dark mods in the extra kit but no 1.5 unit ctrl and alt keys in dark which means the extra kit is only targeting people with newer boards. Also, the base kit includes  a special hhkb layout set which targets a very small audience which is people who either have an hhkb with the mx sliders or someone with one of the various hhkb mx style boards which is possibly infinity (no 6x spacebar though), gon hhkb, winkeyless, or viper. While it's really cool I would much rather have a standard grey and light grey alternate esc and f-row set.
Offline njbair
    • nickbair.net
My boards:
Offline trenzafeeds
  • **** off
« Reply #211 on: Thu, 19 November 2015, 21:17:32 »
This is the thing that would keep me from buying this set. Why can't the dark mods be like the SKIDATA+ color kit.
demik will never leave.
Unless he gets banned.
Offline intelli78
« Reply #212 on: Thu, 19 November 2015, 21:18:54 »
3D Modeling and Rendering Services by thesiscamper
Just sayin.
Wowww I had not seen this before. Yep, I will be contacting him asap.
Offline jiexi
« Reply #213 on: Thu, 19 November 2015, 21:21:57 »
me please
Offline polentA
  • Formerly withoutrulers
  • GMK plz
« Reply #214 on: Thu, 19 November 2015, 21:39:49 »
This set is awesome. I would love to get it.  :D
Offline ideus
  • Björkö.
« Reply #216 on: Thu, 19 November 2015, 22:28:36 »
Question with echo:
intelli: A steep control key? ... a steep control key? ... a steep control key?
You may answer: No, never, forget it.
Edit: In a serious suggestion: You may add a purple 2u backspace to go with the purple number row to allow the row of keys to be used in standard boards keeping its concept of a colorful top line.
« Last Edit: Thu, 19 November 2015, 22:39:17 by ideus »
Offline briancvrrbs
« Reply #217 on: Thu, 19 November 2015, 22:56:58 »
Damnnnnn I'm definitely jumping on this group buy!  :thumb:
Offline clochette
« Reply #218 on: Thu, 19 November 2015, 23:10:32 »
should the dark mod have RGB legends as well?
Offline mrboovn
« Reply #219 on: Thu, 19 November 2015, 23:22:53 »
Damn.It's happened to early.I haven't been ready yet :(
Offline ideus
  • Björkö.
« Reply #220 on: Thu, 19 November 2015, 23:27:10 »
Make it your x-mas self-gift.
Offline dyrdevil
« Reply #221 on: Fri, 20 November 2015, 00:04:55 »
this looks amazing...
Offline Siegx
« Reply #222 on: Fri, 20 November 2015, 00:32:29 »
Dat sexy purple on the SNES.  :-*
Offline gadzkun
« Reply #223 on: Fri, 20 November 2015, 00:32:48 »
so this set had new color from gmk right? awesome :p
Offline turboloser
« Reply #224 on: Fri, 20 November 2015, 01:20:35 »
Yesssssss  :-*
Offline E3E
« Reply #225 on: Fri, 20 November 2015, 01:23:05 »
This keycap set is making me seriously question my Alpsuality. Man, oh man. Yep, this is going to go on my Octagon v2 and I'm gonna get Silver + Titanium grey for the Octagon. This just changed all my plans. Hoooooly crap.
I'm ready to say hello to my first GMK key cap GB purchase. Finally something that has enough pull to seriously blow my mind and ready my wallet.
« Last Edit: Fri, 20 November 2015, 01:27:35 by E3E »
Offline Glenmael
« Reply #226 on: Fri, 20 November 2015, 01:48:26 »
Octagon purchase prior to ever owning a GMK set!?  :eek: :P
Will look awesome with a Silver + Titanium Grey base  :thumb:
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #227 on: Fri, 20 November 2015, 01:54:23 »
Very likely this is going to be my first full GMK set ;D
Gotta find my SNES now!
Offline joey
« Reply #228 on: Fri, 20 November 2015, 05:32:09 »
I wish those coloured punctuation keys were in a smaller extras set, really want those!
Offline Latin00032
« Reply #229 on: Fri, 20 November 2015, 06:00:13 »
It didn't have hhkb support either.
Granted, it's a special set so you can't keep the price too high.
It would make more sense to have some 1.5 mods. It didn't really need hhkb support as much.
Offline asgeirtj
« Reply #230 on: Fri, 20 November 2015, 06:16:21 »
Would be awesome if you could buy the spacebar seperately, light grey to match with a bsp set :)
Leopold FC900 w/ 67g Purple Zealios - Silver Duck Octagon w/ 62 Purple Zealios
Offline trenzafeeds
  • **** off
« Reply #231 on: Fri, 20 November 2015, 06:27:55 »
There was literally no reason for you to use that gif
Offline rpeterclark
  • RPTR ❌
« Reply #232 on: Fri, 20 November 2015, 07:07:14 »
The gif police have arrived. Everyone stop having fun! Thanks trenzafeeds.
Offline soilheart
« Reply #233 on: Fri, 20 November 2015, 10:36:59 »
Would it be possible to add ISO keys (i.e. enter and short shift) to the dark pack? I really dig the look, but as an ISO user it would probably look odd with enter and left shift missing.
(K70 -  Brown) --- Pok3r - Clear --- Ducky Shine4 - Clear --- WKL B.face X2 - 67g Zealios --- CP-SQ - 78g Zealios --- RS68 - 62g Zealios
(Sold/retired - To be built)
Offline ideus
  • Björkö.
« Reply #234 on: Fri, 20 November 2015, 11:26:04 »
What? She is so cute that any reason is good to have her here.  :)) :))
Offline mason
  • have fun with her, ryan
« Reply #235 on: Fri, 20 November 2015, 15:31:09 »
How long will this be up for on MD? Sorry if this has been answered already.
Offline ideus
  • Björkö.
« Reply #236 on: Fri, 20 November 2015, 15:37:51 »
It is over 600 votes already.
Offline Latin00032
« Reply #237 on: Fri, 20 November 2015, 15:50:19 »
It's on MD? That was fast?
« Reply #238 on: Fri, 20 November 2015, 15:51:53 »
Just the poll. The poll's been up there for a while. https://www.massdrop.com/vote/gmk-keycap-sets/result
The total number of votes is over 600, but SNES has over 300. Still, it's in the lead by a huge margin.
Offline mason
« Reply #239 on: Fri, 20 November 2015, 16:26:21 »
I meant how long will orders be open for once it starts?
« Reply #240 on: Fri, 20 November 2015, 16:27:04 »
Not sure how long TA was, but probably the same. I think the longest a Massdrop can last is two weeks.
Offline Data
« Reply #241 on: Fri, 20 November 2015, 21:08:33 »
So many great sets this year.  This one will be a hit.
All Row 4 was an interesting choice.
Offline olijuice
« Reply #242 on: Fri, 20 November 2015, 22:36:15 »
If all the keys are R4 does that mean they will be interchangeable like DSA? I.e. If you wanted to have a Dvorak/Colemak layout?
I've never seen an all R4 Cherry layout, does anyone have any pictures as examples?
Offline aznairjordan
« Reply #243 on: Fri, 20 November 2015, 22:49:22 »
I think that it means that the bottom row is all R4 instead of R4+R5 like some other sets.
TGR Jane CE|FC660C|Orion V2
GMK Hyperfuse|GMK Olivetti|GMK Red Alert|Soulfree's Teal|GMK Cyan
Offline Zealousy
    • Twitter
« Reply #244 on: Sat, 21 November 2015, 01:03:02 »
I've been avoiding going for any custom sets for a while now, but it looks like I've met my match. SNES ahoy!
Offline ideus
  • Björkö.
« Reply #245 on: Sat, 21 November 2015, 08:33:13 »
I was into ALPS several years ago and then, I learned there was no high quality key caps for ALPS, later I found that Cherry double shots are some of the best key caps you can use and that they are only available for Cherry mount, since then, I changed to Cherry and I am very happy now, typing on this super nice OGs. This SNES will be my first full GMK set.
Offline harlw
« Reply #246 on: Sat, 21 November 2015, 14:09:21 »
Can't wait!
Ergodox (x2), V.EA Clone, Tada68, Atreus XL, Planck, Model M 70% Mod
Offline turboloser
« Reply #247 on: Sat, 21 November 2015, 15:47:46 »
God, I need like two new keyboards to go with my sets lol.  :-X
This and Miami Nights will need their own dedicated boards.
Offline aubthedrummer
  • Papa Bless^
« Reply #248 on: Sat, 21 November 2015, 15:56:42 »
I actually really like these. Its a really cool design bringing in the button colors as the wasd keys too
Offline E3E
« Reply #249 on: Sun, 22 November 2015, 00:07:16 »
It will be a long time before we get anything near the level of thickness as GMK/JTK or BSP/Gateron, but there are some OG doubleshots and dye subs that are I'd say .5mm shy of the thickness of the Cherry equivalent. Thick for Alps, kinda thick for Cherry. Strangely, the thick ABS Alps caps seem to heighten the pitch (compared to the Tai Hao DS caps). PBT definitely lowers it.
Yeah, this set is gonna be great. It's creating almost the same spark that Jukebox and the prospect of having a red Octagon did in combination. Now having a Silver Octagon with a Titanium Grey alu base + this set is just calling to me. Ahh, I'm so hopeless in this hobby!
