Author Topic: Does anyone have information about this "Shi-Tec" keyboard?  (Read 3495 times)
Offline boTy
« on: Wed, 05 August 2015, 15:36:53 »
107506-0 Here's a image.
Does someone have information about this board? According to the seller it is mechanical, and the switches feel like a Cherry MX Blue.
Re: Does anyone have information about this "Shi-Tec" keyboard?
« Reply #1 on: Wed, 05 August 2015, 15:39:08 »
Have any other pictures? Maybe of the back or of a pulled cap? That picture and your description aren't too helpful.
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #2 on: Wed, 05 August 2015, 16:24:15 »
Model sticker and switch shot would definitely be useful.
Offline engicoder
« Reply #3 on: Wed, 05 August 2015, 16:31:37 »
I'm always doubtful of any older board that doesn't have at least an inch of body above the top most keys.
Plus, I like somewhere to put my pencil  :D
Offline Touch_It
« Reply #4 on: Wed, 05 August 2015, 16:43:55 »
The layout itself reminds me of omnikey but not the case.  As you mentioned on reddit, it does have a reversed spacebar, as thought, though kinda hard to tell from the pic.  Likely mechanical but I have no idea what.  Ideally the seller would pull a cap for you, as well as take a pic of the back label.  If I had to warrant a guess, I'd say it is some sort of White Alps or White Alps clone.
Edit: Open question.  Has anyone ever seen a RD where you could do a reverse spacebar mod. (without modification to the keyboard).
Offline boTy
« Reply #5 on: Wed, 05 August 2015, 16:44:48 »
Thanks for your reply. I have already sent a message, but he hasn't responded yet.
Offline boTy
« Reply #6 on: Thu, 06 August 2015, 05:13:11 »
He has sent me this picture: http://ic.tweakimg.net/ext/va/1117726.jpg
Doesn't look mechanical, but it may be worth getting for the keycaps. It's only 10 euros.
Offline boTy
« Reply #7 on: Thu, 06 August 2015, 05:14:30 »
He has sent this picture: http://ic.tweakimg.net/ext/va/1117726.jpg
I don't think it's mechanical, but the keycaps look Cherry MX compatible.
« Reply #8 on: Thu, 06 August 2015, 05:19:38 »
I've seen rubber dome keyboards which have alps compatible keycaps. While the ones I've seen have specific spacebars, I would guess there's some that have spacebars you can flip.
Ugh are these the switches that look like futabas but aren't? I always guess futabas on switches that look like these. Those keycaps might be mx compatible but for some reason, I've got a gut feeling that they're slightly off. So I'm not sure :(
« Last Edit: Thu, 06 August 2015, 05:21:19 by CPTBadAss »
Offline boTy
« Reply #9 on: Thu, 06 August 2015, 05:26:05 »
Thanks for the reply, I'll talk to the seller about it.
Offline chyros
  • a.k.a. Thomas
« Reply #10 on: Thu, 06 August 2015, 08:33:08 »
They look like Montereys with Alps- compatible caps Oo .
Offline BrewCaps
« Reply #11 on: Thu, 06 August 2015, 18:18:12 »
Pretty sure it came with a ****y Computer.
Offline chyros
  • a.k.a. Thomas
« Reply #12 on: Thu, 06 August 2015, 19:30:03 »
HA! I knew I was right! Montereys with Cherry mount ^^ .
http://deskthority.net/wiki/SMK_Cherry_MX_mount
Offline boTy
« Reply #13 on: Fri, 07 August 2015, 02:43:44 »
Yep! I've talked with the seller, and i will probably buy it.
He also sells a model M!
