Author Topic: tenkeyless have embedded numpad?  (Read 4407 times)
Offline ds26gte
« on: Sat, 10 October 2009, 06:42:08 »
Do the tenkeyless boards have an embedded numpad?  I don't think I see an Fn key in the pics.   I don't ever use a numpad qua numpad, but I occasionally use it as a quick on-keyboard mouse, via Mouse Keys.  Mouse Keys isn't expressive enough for me to complete avoid the real trackball, so a compact keyboard that allows easy access to the right is still preferable to a board with a actual numpad.
Bloody B820R with LK blues. Logitech Marble Mouse unplugged and inside a drawer for emergencies.
Offline AndrewZorn
« Reply #1 on: Sat, 10 October 2009, 06:59:52 »
num lock is the key you are looking for
Offline alpslover
« Reply #2 on: Sat, 10 October 2009, 08:32:45 »
which tenkeyless?  the filcos do not have numpad functionality.
Offline AndrewZorn
« Reply #3 on: Sat, 10 October 2009, 08:40:57 »
i thought they did
but i dont own one
what else could numlock do on a keyboard with no number pad?
Offline ds26gte
« Reply #4 on: Sat, 10 October 2009, 08:41:32 »
Quote from: AndrewZorn;124277
Hmm, I see a NumLock on the Realforce tenkeyless pic, but not on the Filco.  Filco tenkeylesses don't have an embedded numpad?
« Last Edit: Sat, 10 October 2009, 09:29:17 by ds26gte »
Offline alpslover
« Reply #5 on: Sat, 10 October 2009, 08:51:42 »
i own two filco tenkeylesses.  they do not have an embedded number pad, nor a numlock key.
Offline alpslover
« Reply #6 on: Sat, 10 October 2009, 08:52:43 »
Quote from: ds26gte;124282
Filco tenkeylesses don't have am embedded numpad?
no, they don't.
Offline Rajagra
« Reply #7 on: Sat, 10 October 2009, 08:59:23 »
The TypeMatrix handles it best. You can use the Fn key to access the numpad, or you can use the Num key to toggle it on. This is all separate to the normal NumLock function, so you can use the embedded numpad for numbers or navigation - which is actually useful for Mousekeys.
Offline AndrewZorn
« Reply #8 on: Sat, 10 October 2009, 10:11:02 »
okay, so THAT is what i was thinking about when i was reassured about numpad functionality back in my thread.
sorry for the bad info
