Author Topic: Where to buy switches?  (Read 4712 times)
Offline lolkey
« on: Thu, 06 August 2015, 10:48:43 »
Are there any place to get individual Cherry MX switches that don't cost $1+ each?
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
Re: Where to buy switches?
« Reply #1 on: Thu, 06 August 2015, 10:52:28 »
Which switch type and how many do you need?
If you can swing buying 100 packs I'd shop here https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=43
If you have time to wait you can try 7bit if you only need a couple switches http://deskthority.net/group-buys-f50/cherry-mx-taking-pre-orders-t2760.html
You could always buy a used board off ebay depending on what switches you want and desolder them and get them below your price.
Otherwise posting a WTB in classifieds might help you get small quantities.
I've also bought switches off of taobao but you never know what you might end up getting.
« Last Edit: Thu, 06 August 2015, 11:00:34 by SpAmRaY »
Offline moshimalloe
« Reply #2 on: Sat, 15 August 2015, 22:08:01 »
you can get Gateron switches I heard, which are Cherry MX knock-offs, but good ones at that, some people say they're even better.
amazon has them for $40 for 120 switches! so that's like 33 cents each
good luck!
Offline shawn o
« Reply #3 on: Sun, 06 September 2015, 10:51:47 »
Digikey is $0.89 for a single and less than $0.75 when ordering 100. This is for PCB mount clears.
http://www.digikey.com/product-detail/en/MX1A-C1NW/CH310-ND/280855
Mouser is about the same price. They have over 8000 in stock currently.
http://www.mouser.com/ProductDetail/CHERRY/MX1A-C1NW/?qs=Z9t1pRjfOczFJIu%252bjJwwJg%3D%3D
Offline zzyjayfree
« Reply #4 on: Tue, 15 September 2015, 10:19:20 »
WASD has all kinds of switches, but price is also high, $1.5 each. Not sure if that leads to a higher quality.
OTD 360 Corsa w/ Nixdorf, OTD 356.2 DGE, Matrix 1.2, Matrix 2.0, Matrix Abel, Skog, Dolphin, EM7, Lynn Pad, Plank, LZ-RE, EqualZ, Orion v2, Octagon v2, Viper v2, Tank, Mira, Mira SE, Moon, Camp 225, Let's Split, HHKB, RealForce, Infinity Ergo, Cherry 3700, DolchPac, Nixdorf, Model M, Filcos.
Offline heroinbob
« Reply #5 on: Sun, 25 October 2015, 23:53:22 »
I have some used cherry mx switches (harvested by me from boards).
MX - clears, blacks and browns (some vint blacks/browns)
If you can't find someone to sell you a couple at reasonable rates, let me know.
I only ship CONUS
Paul (HB)
Location - California
Offline Kola93
« Reply #6 on: Sun, 25 October 2015, 23:54:53 »
You might have the best luck posting in the classifieds thread.
Hopefully someone with a custom keyboard project might have one or two extra switches lying around. ^-^
Offline engicoder
« Reply #7 on: Mon, 26 October 2015, 13:21:10 »
good luck!
Didn't realize these were available on Amazon. Thanks!
« Reply #8 on: Mon, 26 October 2015, 13:23:52 »
good luck!
cheaper here https://mechanicalkeyboards.com/shop/index.php?l=product_list&c=77
Offline CaplockJack
« Reply #9 on: Mon, 26 October 2015, 13:26:58 »
Why is this under Keycaps?
« Reply #10 on: Mon, 26 October 2015, 13:28:15 »
only 4 more to go :rolleyes:
Offline engicoder
« Reply #11 on: Mon, 26 October 2015, 14:52:05 »
good luck!
Not sure how 10 for $10 is cheaper than 120 for $40  :)
« Reply #12 on: Mon, 26 October 2015, 14:59:01 »
good luck!
If you add 12 sets of 10 to your cart the total is $36 shipped. ;)
Offline engicoder
« Reply #13 on: Mon, 26 October 2015, 15:54:43 »
Ah...clicking more info revealed all!
Offline moshimalloe
« Reply #14 on: Thu, 29 October 2015, 19:34:25 »
Whoa. I posted that in August haha. I was checking recent posts and saw this thread thinking like "I don't remember posting here"
