Author Topic: Can't reprogram my GH60  (Read 4772 times)
Offline sakai4eva
« on: Thu, 06 August 2015, 12:55:46 »
Hi guys.
I feel like a retard this past week, because a few months ago I upgraded my entire PC but I forgot how I got the drivers for my board.
It's a GH60 Rev_CHN to be exact.
I have managed to install the drivers properly (ATMEGA32U4 shows up in device manager), but every single time the bootloader can't be found.
I'm completely stumped and I feel that I have missed a step or took a few things for granted with my old PC.
Any insight?
Re: Can't reprogram my GH60
« Reply #1 on: Thu, 06 August 2015, 13:01:47 »
Did you install Atmel FLIP? What device does it show when you jump into boot loader mode while it's connected to your PC?
Offline sakai4eva
« Reply #2 on: Thu, 06 August 2015, 13:22:59 »
http://imgur.com/mQJUl7n
Atmel FLIP installed.
« Reply #3 on: Thu, 06 August 2015, 13:24:56 »
Does the device appear to change after you press the button to jump into bootloader?
Offline sakai4eva
« Reply #4 on: Thu, 06 August 2015, 13:34:52 »
yeap. Atmel doesn't show up until I press the bootloader button.
EDIT: headed to bed now. 2:40am will try again tomorrow :(
« Last Edit: Thu, 06 August 2015, 13:36:41 by sakai4eva »
« Reply #5 on: Thu, 06 August 2015, 13:40:17 »
Oh, do you have WinAVR installed?
Offline sakai4eva
« Reply #6 on: Thu, 06 August 2015, 19:11:30 »
IS WinAVR necessary? I'll install that now...
Offline telnet
« Reply #7 on: Sun, 09 August 2015, 11:00:30 »
I had a similar problem where it would stop at "waiting for bootloader...." stage.
What needed to be done was update the driver of ATm32U4DFU device to a WinUSB version by using Zadig which shipped with the latest version of tkg-toolkit.
After that the firmware flashed without issues.
QFR Frosty Flake | 7bit Phantom
Offline sakai4eva
« Reply #8 on: Sun, 09 August 2015, 21:36:00 »
Tried installing Zadig by itself, still no dice.
Offline telnet
« Reply #9 on: Mon, 10 August 2015, 02:03:36 »
What do you see when you have zadig running and have the keyboard plugged in and pressed the firmware button?
