Author Topic: Change layout depending on OS? B.face  (Read 3836 times)
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« on: Fri, 07 August 2015, 02:37:08 »
Hi all!
I've been trying to figure out if it's possible to change layout depending on wich OS I'm using? When I use OSX at work I'd like alt and win to trade places, is this possible or do I have to use a work around with some app for the OSX?
Regards
Re: Change layout depending on OS? B.face
« Reply #1 on: Fri, 07 August 2015, 03:15:03 »
Hi!
You have two options - use an app or get a programmable keyboard and set up a different layer with the keys swapped, then every time you went on the Mac you'd have to hit a combo like control, shift and M for Mac mode (made it weird so you don't press it accidentally!)  Much cheaper and easier to use an app I would think, unless you already have a programmable board.
I don't know anything about Mac but had a quick look and found
You can also remap modifier keys in the Keyboard System Preferences pane.
mentioned here which sounds like a good place to start :)
Offline Oobly
« Reply #2 on: Fri, 07 August 2015, 06:21:10 »
+1.
You could set up your board for Mac hardware-wise and use AutoHotkey to remap it for Windows.
Or get a programmable board with layers that can be toggled.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #3 on: Mon, 17 August 2015, 02:03:32 »
Forgot to mention in the question that it's regarding a b.Face pcb :)
But I found an even better solution! I ordered a another board  :cool:
Offline Thumper_
  • Spend all my money.
« Reply #4 on: Mon, 17 August 2015, 07:25:06 »
That's the best solution.
Offline jacobolus
« Reply #5 on: Mon, 17 August 2015, 07:51:30 »
You can also open up the Keyboard section of the Mac System Preferences, and swap the behavior of the modifier keys there. No need for any keyboard-side changes.
Offline henz
  • What?
« Reply #6 on: Mon, 17 August 2015, 08:55:18 »
i dont know anything about the b.face pcb more than its korean, but if you know how to flash firmware on it, you might be able to get pimp it with TMK firmware,if it has a atmel chip on it.
Offline Vaun
  • ¯\_(ಠ_ಠ)_/¯
« Reply #7 on: Fri, 21 August 2015, 14:30:58 »
When in doubt, buy another keyboard.
Ooooh I didn't know that. That's actually a really good solution, thanks!
