Author Topic: Does anyone know the dimensions of the Varmilo VB87M ?  (Read 2948 times)
Offline tigersharkdude
« on: Fri, 07 August 2015, 15:24:33 »
I am trying to find the overall length of this keyboard but have been unsuccessful. Does anyone happen to know and/or have one that they can measure?
Thanks a bunch
Offline Data
Re: Does anyone know the dimensions of the Varmilo VB87M ?
« Reply #1 on: Fri, 07 August 2015, 16:03:55 »
I can throw a measuring tape on mine when I get home, if someone doesn't beat me to it.
« Reply #2 on: Fri, 07 August 2015, 16:12:37 »
would be MUCH appreciated
Offline Data
« Reply #3 on: Fri, 07 August 2015, 19:51:40 »
I'm home. Will take some measurements momentarily.
Offline Data
« Reply #4 on: Fri, 07 August 2015, 20:33:56 »
I just realized mine is a VA87M and you asked for a VB87M.  Oops...   :-[
Anyway, they should be VERY close if not exactly the same case.  I don't think the BT module adds anything to the dimensions, especially the overall length.  Here it is:
These were just taken with my phone so they aren't spectacular.  Full disclosure: I needed to snap some photos for another poster so this was just killing 2 birds.  :)
Other measurements and more here:  http://imgur.com/a/ok7s8
« Reply #5 on: Fri, 07 August 2015, 20:51:28 »
Thanks. Im pretty sure its 14" for both models, Ive had another user tell me 14 aswell
