Author Topic: What is keycap shine?  (Read 19707 times)
Offline TastaturenAuslese
  • Formerly temence
  • life marrow suckerer
« on: Fri, 07 August 2015, 16:15:38 »
I've had this question on my mind for some time now.
Is shine:
(1) the result of your finger oil's sticking to the caps;
(2) the result of constant use rubbing away the texture on top of the caps and kind of "sanding" it down to a shine; or,
(3) a combination of both?
2 makes more sense to me, because PBT, being a stronger material than ABS, is more resistant to shine. If 2 were true, then it's because PBT is harder and thus not as easy to sand/polish down to a shine with your fingers.
Any thoughts? :3 For keyboard science, of course.
Home: Kishsaver - IBM 6019284/F62 | Work: HHKB Professional 2 Silenced | Temporary Retirement:
IBM '89 1391401 Merrill Lynch Financial Edition
They are a functional and practical indulgence.
  • Live long and prosper
Re: What is keycap shine?
« Reply #1 on: Fri, 07 August 2015, 16:16:40 »
2, as a result of 1 + 2
so 3
but mostly 2
tp thread is tp thread
« Reply #2 on: Sat, 08 August 2015, 05:47:12 »
1 in the short term, 2 in the long term.
Offline Zensuji
« Reply #3 on: Sat, 08 August 2015, 06:52:10 »
Its where you keep taking a shine to new sets and can't stop buying them
Offline Magna224
« Reply #4 on: Sat, 08 August 2015, 07:56:51 »
Keycaps are worn down to the point of shining. Wearing down the texture. It might be oil/dirt on human hands though as I've never worn down keycaps to the point of shine myself even cheapo stock keycaps.
« Last Edit: Sat, 08 August 2015, 07:59:31 by Magna224 »
« Reply #5 on: Sat, 08 August 2015, 07:59:47 »
Offline Oobly
« Reply #6 on: Sat, 08 August 2015, 08:16:36 »
so 3
but mostly 2
+1
Embrace the shine...
107785-0
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline BucklingSpring
« Reply #7 on: Sat, 08 August 2015, 14:58:08 »
And as you mentioned, some material more prone than other.
Topre spacebars are notorious for premature shining.
Boards I own, click ->
« Reply #8 on: Sat, 08 August 2015, 21:26:53 »
What exactly is considered premature?
And op, keycap shine is what some people here that treat keyboards as fashion accessories complain about. Can't let a little shine ruin it matching the rest of your outfit!
Offline Data
« Reply #9 on: Sun, 09 August 2015, 20:56:14 »
It's wear. Some materials wear faster than others. Your skin oils don't really react with the polymers in any meaningful way, but they do lubricate the contact with your fingers so, in that sense, oily hands might help to reduce wear-related shine. But mostly it's just friction. Your fingertips effectively polish the caps. The skin on your fingers grows back. The plastic surface on your caps doesn't.
I guess if you have really, excessively oily hands that could add to the appearance of shine on your caps. So clean your damn keyboard. :p
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #10 on: Sun, 09 August 2015, 21:11:18 »
Shiny Nuclear DSA is the way it was meant to be.
Offline Bevo
« Reply #11 on: Sun, 09 August 2015, 21:41:50 »
I can tell that you're a camper. Never using W to move forward.
Offline Oobly
« Reply #12 on: Mon, 10 August 2015, 03:29:00 »
Or maybe he doesn't play games at work...
It is an interesting wear pattern, though. I notice the "E" is not worn as much as "D" and even "F"... Which doesn't match English character usage, so what language does JD type in?
Could of course be more related to finger resting positions, but keeping your fingers on the home row is not ergonomic.. forces poor ulnar deviation.
« Reply #13 on: Mon, 10 August 2015, 06:00:29 »
SA??
Offline Oobly
« Reply #14 on: Mon, 10 August 2015, 07:17:50 »
SA??
Perhaps he has some tritium-infused DSA caps that actually shine... as in "glow".
Worn-in SA caps are where it's at. The true typing experience.
Offline katushkin
  • Just the guy
« Reply #15 on: Mon, 10 August 2015, 09:22:20 »
SA??
Yes. I always get confused.
« Reply #16 on: Mon, 10 August 2015, 09:33:36 »
Got it in one. I'm not much of a gamer, anyway, but that is my work keyboard.
I type in English. :)
I rest the fingers of my left hand on ASDF. My right hand rests on my mouse. I often move my left hand over the caps, which causes them to shine even faster. I can tell that this is terrible for my hands, because I have recently begun to notice the symptoms of osteoarthritis in my hands and wrists, and my keyboarding just aggravates the symptoms.
