Author Topic: Looking for first keycap set  (Read 1882 times)
Offline Notorious
« on: Fri, 07 August 2015, 22:55:40 »
Hey guys! I'm looking for my first keycap set for my new keyboard. I found one set that I really like, but I wasn't sure if it was good quality or not. I'm looking for white thick pbt with black legends. So far this is the closest thing that I found, they fit my criteria, if I can just find thicker maybe? or are these already considered thick at 1.0mm thickness? If anyone has experience with these or can suggest a better keyset quality that is pretty much the same thing I would appreciate it ^-^
I'm rocking a Filco Convertible 2 if that helps
http://www.geekkeys.com/white-dyesub-pbt-104-keyset-black-fonts/
also, where can I find media control stickers to put on the side of the keycaps? I saw someones keyboard on here that had a custom keyset but it looked like he put stickers all over the side of his keycaps for the new functions that he programmed. I would pull it up but I can't find it again.
